- MilkyWay Galaxy
You stated the voltage never varies, are you sure when you put the TPS on that the tang is on the correct side. Once a long time ago, I replaced the TPS and put it all together and I had problems. I can't remember exactly what they were. The lever on the TPS needs to be preloaded when it is installed. I got the lever on the side so as the throttle was opened, it never rotated the TPS.
I thought of that, had that problem once too, but as I recall it was obvious right away as there was no changing signal to the ECU as you gave it gas. It might also have a low idle??? Wish I could remember what the differences were, but it must have been 10 years ago now. Worth asking the question though.
