RWKHausSupply
- yorba linda, Cali
I have leaky inner seals on the front D30 and was thinking that why not just use the outer highend type tube seals to fix that as well as keep crap out of there.
My question though is if they will fit the ocer like 1995ish D30, they list 97-newer, and if they can be used to keep oil in the tube/housing?
I was thinking that why cant I just go ahead and let the tube be a wet setup and just make sure that I keep enough oil in the tube to where it wont want to run in to the tube anymore.. basically just keep the oil level about .25" above the inner seal as well as .25" high in the tube. But will this seal hold that?
Thanks
Thanks
