Old March 6th, 2018, 17:52
alexgalexg's Avatar
alexgalexg alexgalexg is offline
Alternator help
I'm hearing a lotnof bad things about auto parts stores over the past couple years. I grew up putting in auto store parts that lasted just as long as factory. Those days are dead and done. I'm not the only one experiencing this. I'm pretty sure they listed a brand new non reman denso on rock auto. This was just the most expensive hearted option so I figured maybe it was better
Old March 6th, 2018, 19:24
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Alternator help
New or rebuilt Denso would be my choice Iíve had very good experience with the Denso brand, starters, alternators, ignition coils, radiators, etc.
Old March 6th, 2018, 19:53
ehall's Avatar
ehall ehall is offline
Re: Alternator help
all reman are crapshoot. You can usually buy a new AC Delco on Amazon for the same price or less.
my '91 beater rebuild
Old March 7th, 2018, 06:05
alexgalexg's Avatar
Re: Alternator help
The one I linked was an AC Delco. It is listed as new not reman cool I'll order it
Old March 13th, 2018, 09:02
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Re: Alternator help
As for the noise, check the belt alignment. There is the possibility that the balancer or another pulley is on its way out and causing alignment issues.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old March 13th, 2018, 09:53
alexgalexg's Avatar
Alternator help
Balancer and pulley are new. Dropped that engine in summer 2016. Replaced the alt since it didn't work when wet. The noise turns out to be that fan pulley which is a horrible design. It's pressed... not bolted into the a.c. bracket. If I can find a shop that has a press that will work to get it out ill have them do it because I don't have the right press. Otherwise I guess I'm spending like 300 at the dealer for a new bracket with pulley bearing
Old March 15th, 2018, 22:28
MitchXJ89 MitchXJ89 is offline
Re: Alternator help
89 Xj, 4.0
Bought an alternator from DB electrical along with new cables from Paul at jeepcables.com. Set everything up and the Jeep started right up. Drove around for the day and parked over night. Came out the next day and the Jeep was dead. Put the battery on a charger for maybe 15 minutes and had enough juice to start and stayed running. Went to autozone to test the battery they said itís fine but the voltage regulator is bad. I get itís common for remans to come broken every now and then, but why me? 😅
So I guess my question is, has anyone used DB electrical stuff before?
Old March 16th, 2018, 06:15
alexgalexg's Avatar
Re: Alternator help
Originally Posted by MitchXJ89 View Post
89 Xj, 4.0
Haven't used that brand but sounds like it's shorting out some place or has a bad connection
Old March 16th, 2018, 06:19
Alternator help
It could be bad, unfortunately rebuilt quality is crap these days. Luckily the Renix alternators are GM internally regulated.
If it tests good outside the Jeep check the plug to the voltage regulator.
Old March 16th, 2018, 10:55
Re: Alternator help
I donít think thereís a short anywhere. I triple checked all the new cables I installed and put a washer on the alternator so the terminal sits a little prettier. Watching my voltage gauge bounce a bit but never hit 14. DB electrical has good warranty and returns policies but I need to ship the old alternator back for them to fix it. Most likely going to take it to a shop to try to skip the shipping from Washington to Tennessee and back. Thanks guys. Once itís working Iíll let you all know how well it performs since I couldnít find diddly about them in the Jeep Community
Old March 16th, 2018, 10:57
Alternator help
Did you test the plug for the regulator? Iíve had them need to be cleaned or wiggled to start charging.
Old March 16th, 2018, 13:15
Re: Alternator help
Iíll see. I checked the wires again last night except the plug to the alternator and got a more active charge. Not the 14 volts I was looking for. Iíll pick up some electrical cleaner later and report back if thereís any difference.
Old March 17th, 2018, 08:26
Jeep Driver Jeep Driver is offline
Re: Alternator help
Powermaster, buy it once.
Old March 17th, 2018, 09:02
Hypoid's Avatar
Hypoid Hypoid is offline
Re: Alternator help
I looked up DB electrical, not a bad price before shipping. If there is another automotive supply in Puyallup, have them check it also.
If the problem actually is the voltage regulator, they are easy to replace.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old March 17th, 2018, 11:28
Re: Alternator help
Went to a recommended alternator shop and had the shop owner test it for me. Working perfectly fine. So Iíll check the regulator plug. The owner of the shop told me to check the next connection over from the widest blade. Says when the key is on the connector is live.
LED Alternator Light with PCM Controlled Alternator??? ROKRWLR Modified Tech Discussion 0 March 25th, 2015 07:43
Different alternator brackets for different years/alternator upgrades for a 2000? krakhedd Modified Tech Discussion 6 February 15th, 2014 10:53
WJ 4.0 Alternator Bracket - Relocate the Alternator on Your XJ freerider15 For Sale: Private Party Only. XJ ITEMS ONLY 5 July 29th, 2013 18:31
I upgraded my alternator to the 136a alternator from a ZJ whats next? Demolition_x Modified Tech Discussion 16 July 22nd, 2011 09:18
Alternator Relocation / Alternator Upgrade Jamescad04 Modified Tech Discussion 6 April 1st, 2011 20:21
