Old January 9th, 2019, 17:55
oldbill oldbill is offline
Crankshaft diameter for main bearings 4.0l engine
Can anyone tell me what the diameter of a standard size journal for the main bearings is n a 4.0L engine? Also do you know the thickness of a standard main bearing. I saw on you tube where a mechanic machined the threads off of a bolt and then machined down the thickness of the bolt head and used that to spin the main bearing in and out with the crank still installed in the engine. I'd like to make one in advance for my engine.
Thanks,
Bill
Old January 9th, 2019, 20:05
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Crankshaft diameter for main bearings 4.0l engine
https://www.youtube.com/watch?v=jHeO1h3U4GE
Old January 10th, 2019, 00:57
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Learned this one as a teenager. The cotter key.
http://repairguide.autozone.com/znet...5280251767.jpg
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old January 11th, 2019, 03:55
8Mud's Avatar
8Mud 8Mud is offline
May be worth a look before you start, just in case your engine isn't standard.
Been my experience the mains are less a problem than the connecting rod bearings and the connecting rod bearings wear much quicker than the mains do.
Second tip. just doing the bearings without facing the crank may be a waste of time, the crank often wears more in one area than the other and not constant across the face. Third tip a little loose is better than too tight.
Old January 11th, 2019, 03:56
8Mud's Avatar
Jeep 4.6 Stroker Parts (crankshaft, rods, bearings, injectors, adj. map) RoyalXJ NAC Classifieds 16 February 13th, 2011 02:12
Jeep 4.6 Stroker Parts (crankshaft, rods, bearings, injectors, adj. map) RoyalXJ For Sale: Private Party Only. XJ ITEMS ONLY 6 March 10th, 2010 17:25
Rear Main Seal STUCK! Pull crankshaft? 95cherokee33s OEM Tech Discussion 7 January 6th, 2007 21:21
front main crankshaft seal garfer03 OEM Tech Discussion 30 November 11th, 2005 13:20
Main bearings and rod bearings old88xj OEM Tech Discussion 32 July 24th, 2003 14:07
