Jeep Street and Performance Do you like to go fast in your Jeep? |
Thread Tools | Rate Thread | Display Modes |
needing some help
I am interested in a doing some performance upgrades to my 91 cherokee. I am going to be undergoing a top end rebuild and I would like to know where to look for a few parts and brands to buy. I am needing the following:
-headers -intake manifold(?, maybe I might just port it and clean it up then gasket match.) -throttle body I am not looking at anything to aggressive, I am not trying to make a racer just get a little better performance out of my rig. Also any recomendations of a good lift kit I am wanting to do a 4 inch suspension lift and could use a good brand to go with. I am not wealthy so I need to do this a the cheap, I can spend maybe 3K max to finish the truck completely including paint. thanks, |
#2
Re: needing some help
Please use the search feature. All of your questions have been asked hundreds of times and the info is there if you just take a few minutes to look for them.
#3
Good luck. Especially if you choose to buy anything other than the cheapest paint job Maaco paint job out there.
#4
^^^^^^^^^ That guy would just say use the rattle can paint job. Personally I blew my budget build away many moons ago. What I wanted and what I could really afford, rarely ended up being the same thing.
#5
Go with a 99+ intake manifold. Do a mild home port and polish on the head, followed by a 3 angle valve job with the valves back cut 32*. I would recommend the APN header. For the TB get a 63mm from www.strokedjeep.com. For lift look a RE 3.5" or you can try iron rock offroad.
#6
Only if it was a quality rattle can job
#7
It all depends on how much money you're willing to invest in the project. I'm assuming you've got a 4.0L (if not, sell it now and buy a 4.0L. ![]() Again, it all comes back to how much money you have to spend. Start off with the basics.... a cold-air intake with a K&N cone filter and a Flowmaster muffler would be a good start. Next would probably be a 62mm throttlebody from eBay and a more aggressive cam. Then a set of headers, port/polish job on the head, set of roller rockers, higher compression pistons, etc......\ It's all a matter of how much you want to spend. Hell..... for $3500 (IIRC....), you can get a longblock 4.6L stroker engine making a guaranteed 260hp. Can't remember where I saw this, but if you're interested, I'll look it up for you. ![]() |
#8
Cold air intakes are a waste of money unless you take the extra effort to completely seal off the filter from the engine heat, and make sure outside air can easily get to it. There is nothing magical about a cone filter, the tube style intakes are only good if they are insulated. Otherwise they will perform worse than the stock air box. |
Thread Tools | |
Display Modes | Rate This Thread |
Needing another Vehicle | redneck | SEC For Sale / Wanted Forum | 4 | August 17th, 2009 20:34 |
Looking at an '87 Needing Clutch and W/P | strubby | OEM Tech Discussion | 1 | December 20th, 2007 07:40 |
Needing some gears. | ccary11 | MWC For Sale/Wanted Forum | 3 | August 21st, 2007 07:23 |
needing more advice... | mmmMUD96xj | SoCal Chapter | 8 | January 22nd, 2007 17:24 |
New person needing a bit of help | badron | Jeep Street and Performance | 3 | October 18th, 2006 10:36 |
