Front hub specs
Zoro
Colorado
Anyone have a link to a detailed drawing with dimensions of the front hubs? My TSM/FSM shows detailed drawings but without percise measurements. I'm working on a custom project designed around an XJ wheel and will need to build a new hub from scratch as it's driven from a keyed shaft.
Most important measurements needed are the diameter of the lug stud holes, diameter of the circular plate face of the hub and the diameter of the collar.
They are different though out the years!
Sorry, misunderstood what your trying to do.
I suggest reverse engineering, measure one.
Can you not measure one?
If not I can take measurements from one for you.
