Old August 13th, 2019, 15:59
pencilrunner pencilrunner is offline
4.0 swap '00 in a '97 (help!)
Hey y'all, need help on something.
Got a '97 with a cracked head (0630 stamp) and a ton of coolant in the oil. I'd be risking it with the bottom end bearings, for sure, without doing a replacement of these, too.
Also have a '00 with a good engine. Would like to just swap the engines.
'00 has the coil pack, '97 has the dizzy. Can I simply install the dizzy, etc, in the '00 engine and drop it in?
Thanks, everyone. On a serious budget here, for sure.
Old August 13th, 2019, 16:18
RCP Phx RCP Phx is offline
Re: 4.0 swap '00 in a '97 (help!)
Yes, the motor doesn't know what year it's going into.
Old August 13th, 2019, 20:16
lawsoncl lawsoncl is offline
Should work. Hope that 2000 motor doesn't had a bad 0331 head (jinx!). Here's a good engine swap thread, btw.
https://www.nc4x4.com/forum/threads/...r-jeep.176054/
Old August 14th, 2019, 06:17
You guys rock. Thank you soooooo much. Helping out a good kid with tight funds, and it's wholly appreciated!
Old August 14th, 2019, 07:26
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Assume the 0331 head is suspect, and replace it with a junkyard part that has been inspected. That NC4x4 engine swap posting has some major errors, and incorrect assumptions, but the basic info is any XJ/ZJ/YJ 4.0L block will interchange.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
2wd mj swap to cherokee 4.0 swap (4wd) Davidson6907 Jeep Comanche MJ (1985 - 1992) 2 February 26th, 2019 06:33
88 4.0L Renix to 96 4.0L HO swap...full swap? swommack2 OEM Tech Discussion 8 June 24th, 2017 07:38
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 22:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 08:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 20:26
