Old August 10th, 2019, 22:38
bajabronco bajabronco is offline
Getting 0455 CEL Evaporative Emission System - what should I look at first?
I am getting the stupid 0455 CEL code fairly frequently now after my Rubicon trip. The gas cap has been changed out and is good. What are the other things I should be checking? I don't smell anything near the fuel tank. Any recommendations on what to check and in what order?
Old August 11th, 2019, 06:32
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Getting 0455 CEL Evaporative Emission System - what should I look at first?
A basic Google search find this:
P0455 JEEP - EVAP System Large Leak
Possible causes
•Missing or loose fuel cap
•Incorrect fuel filler cap used
•Fuel filler cap remains open or fails to close
•Foreign matter caught in fuel filler cap
•EVAP canister or fuel tank leaks
•EVAP system hose leaking
•Fuel tank leaking
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old August 11th, 2019, 06:38
RCP Phx RCP Phx is offline
Year would help....
Old August 11th, 2019, 10:26
Tim_MN, I know what the error code means, I was just asking if people have had personal experience of solving the code, other than just getting a new gas cap, which I have already done.
RCP Phx, it is a 2000 XJ.
Old August 11th, 2019, 11:04
Tim_MN's Avatar
Evap system hoses, hose fittings, and fuel tank hoses, fuel tank vent tube, or the fuel pump assembly lock ring gasket would be likely suspects.
Old August 11th, 2019, 11:35
Check everything at the canister, which is just in front of the gas tank. Then you have another line that runs forward to the purge valve.
Old August 11th, 2019, 12:52
Ok thanks RCP Phx & Tim_MN! -It will be a maintenance Sunday on the XJ today. Yesterday was install the new Method beadlock day !
Old August 12th, 2019, 19:57
97xjnova 97xjnova is offline
Check the line from tank to canister
P0454 Error Code Evaporative... WB9YZU Modified Tech Discussion 7 November 28th, 2012 16:03
Evaporative Emissions Leak (gross leak) bmyohn OEM Tech Discussion 7 July 11th, 2008 12:05
CODE: Evaporative Emission Control System Leak Detected XpedientJ OEM Tech Discussion 1 January 24th, 2008 14:56
OBDII Error: P0455 - 455 A large leak has been detected in the evaporative system...? xL8 APEKSx OEM Tech Discussion 11 May 24th, 2007 21:42
Emission help azjeeps tj&xj OEM Tech Discussion 5 May 5th, 2006 00:38
