Old August 5th, 2019, 18:32
vujakovich vujakovich is offline
P0743
I have a question regarding this code, if anyone can chime in. I have read through all the threads regarding this, but I still can't figure this one out. I tested my solenoids at the TCM and at the dipstick connector. I show the correct OHMS on two of them, but on the Lock-out solenoid I am reading OL, which on my meter is open circuit. All of the wiring under the jeep looks good and I don't see any issues. My main question is, if the lockout solenoid is bad, would it read open circuit and not shows OHMS? I have read that a bad one will show higher ohms, but can a bad one show open circuit?
Old August 5th, 2019, 21:21
lawsoncl lawsoncl is offline
Re: P0743
Open circuit means no connection at all. So either the wiring to the solenoid is damaged or the wiring inside the solenoid is broken. I have seen the connector at the solenoid come off too. I'd say measure directly at the solenoid since you already checked at the firewall, but if you're going to pull the pan, you might as well spend the $55 and have a set of solenoids ready to install.
https://www.amazon.com/Hotwin-Transm.../dp/B07JB4D876
Old August 14th, 2019, 01:25
tm8chris tm8chris is offline
Re: P0743
Had the same problem and the culprit was a bad wiring harness to the trans.
Old August 14th, 2019, 12:17
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Re: P0743
I would agree with lawsoncl and tm8chris. There really is not very much to the circuit between where you measured and the actual solenoid. It's wiring/connectors/solenoid for sure.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old August 17th, 2019, 16:04
Re: P0743
Just to update this. I took off the pan and measured at the solenoid, still open circuit. I removed the solenoid and tested it, it still tested open. So the lockup solenoid was bad. The new solenoids I bought all tested around 12.6, I replaced all three while I was in it, and problem solved. So a bad one can read open circuit, must be an internal problem with it. I thank you guys for the help.
Old August 17th, 2019, 16:24
RCP Phx RCP Phx is offline
Re: P0743
That's the most common scenario.
Old September 7th, 2019, 17:09
Re: P0743
Well, I have been getting bad gas mileage, so I bought a scanner. I don't have a check engine light on anymore, but when I scan my truck I get P0743, and P0753 now. I clear the codes and they will come back. All three solenoids are showing the correct ohms from the computer and the harness. Any idea where to go from here?
Old September 8th, 2019, 08:45
Re: P0743
Is it shifting okay and the torque converter locking up otherwise?
Old September 8th, 2019, 12:41
Re: P0743
Everything seems to be normal. It shifts good on lower range. When I am at 60 and lightly hit the brake, it will increase a couple hundred RPM.
P0743 on a 98 XJ with no Driveabililty Problems 98NWCherokee OEM Tech Discussion 14 July 9th, 2013 18:48
Codes P0700 and P0743 - Cant pass emissions and get tags until cleared. epitaphmike OEM Tech Discussion 4 June 17th, 2010 15:36
OBDII DTC p0700 p0743 Original_MudButt OEM Tech Discussion 4 January 24th, 2009 16:56
98 XJ - P0700, P0743 error code keithmo OEM Tech Discussion 2 October 18th, 2008 17:14
