Old August 6th, 2019, 12:57
nrwphoto nrwphoto is offline
E-fan schematic?
Does anyone know where I can find a wiring schematic for a second electric fan?
I have additional connectors so I can add another 40A fuse in the factory fuse box. I want it to only work when the ignition is on and it will be on a separate temp sensor form the A/C condenser fan.
What signal source is popular to use for “key on”.
Old August 6th, 2019, 18:35
bajabronco bajabronco is offline
Re: E-fan schematic?
I just tapped into the fuse box in the passenger side kick panel. I just used a test light to find one that was on during start-run and used a tap in like this one .
and used that to activate the relay, and then ran the power from the battery to run the fan.
There is also a dark Blue/White wire that can be tapped into off of wiring harness in the engine bay
You can probably use the aux fan override write up to find the wire in your engine bay if you wan to tap into that. https://www.naxja.org/forum/showthread.php?t=1025399
Here is a general aux fan wiring diagram -
Old August 7th, 2019, 12:31
old_man's Avatar
old_man old_man is offline
What year? My renix already had a pigtail for the fan.
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old August 8th, 2019, 10:44
Afireinside Afireinside is offline
My 91 also had it. I needed to add the relay and a fuse and it worked as it should. The vehicle never came with the 2nd fan. It was easy to add.
Old August 8th, 2019, 16:41
CSpeade51 CSpeade51 is offline
E-fan schematic?
Don’t use fuse taps. Run relays and fuse your new system at the source. The key switch has the acc and run wire on it. If you want to get real red neck just put a relay inline with that wire and it can complete the circuit and close the relay for the power for your fan system. That would be much safer and easier than the fuse tap
Old August 9th, 2019, 12:05
Mine is a 2001. I did notice a pigtail in front of the radiator but I assumed that was for the optional outside temp sensor.
A few years back I had a 98’ with the UpCountry package and overhead console/information display.
Thanks for the wiring diagram. My current confusion is the factory condenser fan is not coming on with the A/C, only when the engine hits 220 as secondary cooling. I have checked and when I turn on the A/C the 40A fuse is getting voltage.
Old August 9th, 2019, 14:32
nrwphoto, I have a 2000 XJ - and I put my fan on a manual override switch, following the directions that I posted earlier. so now when I am wheeling I simply flip it on when I need to and it keeps the rig nice and cool. I just went out and checked my XJ, and the electric fan does not kick on automatically just when the AC is activated. It might just be temp based.
Old August 9th, 2019, 18:57
Heavyopp Heavyopp is offline
My 2000 E fan will not kick on just by turning on the ac — kick on for mine is definitely temp based
I did do an E fan override switch on my 96 although that one does kick on with the AC compressor
Old August 10th, 2019, 19:50
Bajabronco and Heavyopp, thanks for checking your fans. Guess I just remember wrong. I will definitely be rewiring the fan to be on a switch or at least at a lower temp.
As warm as these engines run in the small engine bays of the XJ I was really surprised to see that they have 2 cats immediately after the manifold. I knew they switched to 4 O2 sensors and multiple cats to continue meeting CA emissions but that’s a lot of extra heat.
Wiring schematic for '99 XJ wasillashack OEM Tech Discussion 2 April 12th, 2017 10:20
FitchVA schematic Bdiddy11 Modified Tech Discussion 0 October 29th, 2012 07:02
Wiring schematic? Jump This OEM Tech Discussion 3 August 29th, 2011 15:26
Help !!! I need schematic for TCU AW4 XJ '88 lugu50 OEM Tech Discussion 3 August 27th, 2009 11:32
HELP Looking for AW4 TCU schematic !!!! lugu50 Modified Tech Discussion 1 August 27th, 2009 06:58
