Old August 9th, 2019, 09:08
CLSegraves CLSegraves is offline
Re: Running "hot" at idle
Originally Posted by jk_surgeonfish View Post
Nice that you got it resolved. When was the last time you drained/flushed prior to the incident? Just curious as to how long it took to cause the radiator to plug. I flush my yearly and each time it looks new when draining.
Probably 6 months ago and it came out clean at that time.
As I said, I think the new pump (which is supposed to flow 20% more) likely caused scale and "junk" to come lose in the block and it got swept into the radiator. Fortunately it wasn't "sludge", just particles because the radiator shop was able to back wash the radiator and thereby clean out the tubes.
Old August 9th, 2019, 09:44
jk_surgeonfish jk_surgeonfish is offline
Good to know...thx.
Won't stay running, except with key held in "Start" position JiggaLoew OEM Tech Discussion 8 September 22nd, 2014 11:39
Transmission clunking/ engine revving super high at idle / "driving itself" HELP ambitious98xj OEM Tech Discussion 6 January 22nd, 2012 21:37
Who's this "Carol.92124" wench that's running for Treasurer? Carol.92124 SoCal Chapter 45 December 2nd, 2009 12:52
Running hp44/9" full width axles on 37x12.50x15 tires--How much lift/b.s. on 8" rims Big Red Modified Tech Discussion 10 January 27th, 2005 15:36
RePost: DeeZee "running board steps" as rock guards? redxjjoe Modified Tech Discussion 2 December 21st, 2003 17:05
