Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep CJs and Wranglers > Wrangler YJ, TJ, and LJ (1987 - 2006)
Wrangler YJ, TJ, and LJ (1987 - 2006) Technical forum for the Wrangler YJ, TJ, and LJ Unlimited.
Old December 7th, 2017, 09:21
REWSTER's Avatar
REWSTER REWSTER is offline
BACON!
04 LJ 42rle trans fluid puked out the dipstick tube doing 75 down the highway
42rl or 42rle trans. I think there are two different ones.
Anyway, I'm cruising down the highway today and it looks like the trans puked a bunch of fluid out the dipstick. A big cloud of smoke from hitting the engine, and while it was happening it seemed like it was down shifting or trying to at least. I pulled off to the side saw where it was coming from and limped it to the next exit. It was able to shift and run all the way to about 50 but it didn't want to go any further than that and I didn't want to push it. Got it to work, right off that exit, and just went to check the level. Well I'm a dumbass and left my lights on so my battery is dead. But cold not running the fluid is clean,red and above the full hot line, but that is not running.
The cooler lines look ok bit I'm kinda leaning towards a plugged line or cooler. What are your thoughts?
"A Good friend will bail you out of jail but...A True friend will be siting next to you saying damn we screwed up..."
Originally Posted by XJ&CHZ4ME View Post
I'd rather lick guacamole off hobags balls .
Old December 7th, 2017, 16:51
REWSTER's Avatar
BACON!
Re: 04 LJ 42rle trans fluid puked out the dipstick tube doing 75 down the highway
https://www.scribd.com/doc/23066699/...dium=affiliate
For later use
Old December 7th, 2017, 17:08
REWSTER's Avatar
BACON!
I bypassed the cooler... no fluid out of the dipstick. But it didn't want to shift out of first. I thought I mentioned this in the first post. but after I re read it, it appears I didn't. For as long as I've owned this jeep it had some quirks with the trans for a while I just thought it was under geared. But for the last several months I've noticed it getting worse, it woldnt really hold on to a steady speed. I had to hold the pedal down and run at almost 4k on the tach.just to do 75.
Any one have any thoughts on this Trans. I remember my old 02 WJ with the same trans having issues too.
Old December 8th, 2017, 05:41
cabjeepster's Avatar
cabjeepster cabjeepster is offline
Have you tried to shift it manually? Does it throw any codes? I know you said you fixed the fluid out the dip stick but every time I had that
Happen on a turbo 350, 700r4 etc it ended up being a bad front pump.
Tan 1995 XJ AW4 4.0, HD Offroad Cage & Frame stiffeners, D30 (Aussie Locked), 8.25 rear w/disk brakes (Lock Right), 4.56 gears, PORC SYE, 4" Lift, 33's, etc etc...
Craig
Originally Posted by cherokeefreak You probably have an 8.8 because they came stock in some cherokees with the offroad package.
Old December 8th, 2017, 06:09
macgyvr's Avatar
macgyvr macgyvr is offline
NAXJA Member #120
that snap you sent last night. was the fluid as nasty as it looked? all brown and such?
the trans is kind of goofy I think, but mine only has 81k on it and no real issues...yet.
did you change the filter too?
mac 'tranny talk' gyvr
MWC President / Past President
It's always a good time to join or renew your membership!
My idea of a perfect vacation is a road trip through beautiful country. To make it really fun, all that's needed is a modified vehicle, a few close friends, and some serious off-roading. Cole Quinnell - Editor, 4WOR, Dec 99
Old December 8th, 2017, 11:45
REWSTER's Avatar
BACON!
It was more brown than red. But no metal flakes in the fluid. Bottom of the pan has some gunk. I haven't put anything back together yet but my plan is fresh fluid and filter. Luckily I already have about 5 quarts of +4 so if I need to drop it again it's not a big deal.
Old December 8th, 2017, 13:00
macgyvr's Avatar
NAXJA Member #120
I'd probably change it a couple of times.
mac 'it looked bad' gyvr
Old December 8th, 2017, 17:57
old_man's Avatar
old_man old_man is offline
So you are running Dex 4????
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old December 9th, 2017, 21:11
REWSTER's Avatar
BACON!
Atf +4 mopar stuff.
Old December 10th, 2017, 14:07
REWSTER's Avatar
BACON!
Changed the filter and fluid. Took it for a couple drives and it appears to be stuck in 2nd gear. Through the magic of the internet that means it's in limp mode,that explains the cel that won t go off now (was not on before the fluid problem). Now I can't remember what happened first the down shifting or the fluid spitting out. So I'm going to do some more research I saw a couple post about TCM problems and solenoid pack problems both high dollar fixes. I'll be back with more info since I know the LJ guys are multiplying here.
Old December 10th, 2017, 15:58
Bryan C.'s Avatar
Bryan C. Bryan C. is offline
Member #674
Any idea what code it is setting? Figure that out first.
Old December 12th, 2017, 15:42
REWSTER's Avatar
BACON!
Yeah. Got my brother over here with a scanner. It had a couple. P0733 p0743 p0218 p1790 and p0944.
After clearing them and a quick drive. It slips going into 3rd. And the p1790 and p0944 came back.
Old December 12th, 2017, 21:25
macgyvr's Avatar
NAXJA Member #120
Try disconnecting the battery for a a few hours.
Is the fluid full after warming up?
Do you have a trans shop you trust nearby that can plug in and drive it?
mac 'inquiring minds' gyvr
Old December 17th, 2017, 11:23
trippled trippled is offline
With those 2 codes I'm gonna say it doesn't look good. To verify, you are setting fluid level in nuetral? I looked both of those codes up on identifix and most where either fluid level related or trans died.
Old January 6th, 2018, 21:22
REWSTER's Avatar
BACON!
put input and output speed sensors in just to make sure it wasn't something cheap and stupid. it wasn't.
anyway here is a list from wikipeda of vehicles that use the same trans for later.
42RLE
20052010 Chrysler 300
20062010 Dodge Charger
20042011 Dodge Dakota
2004-2009 Dodge Durango
2005-2008 Dodge Magnum
20072011 Dodge Nitro
20032013 Jeep Liberty
20032011 Jeep Wrangler
2009 Dodge Challenger V6
2003-2012 Dodge Ram
Rate This Thread:
TJ 4.0 motor and 42RLE trans ryan13 NAC Classifieds 2 August 29th, 2016 04:40
Tranny issues, puked fluid out the front seal but is not leaking now? xjtrailrider OEM Tech Discussion 6 June 30th, 2013 13:08
Auto trans dipstick tube DieselAirman OEM Tech Discussion 2 August 26th, 2009 18:07
Any idea where to get a new trans(AW4) dipstick tube Beetlejuice OEM Tech Discussion 2 October 17th, 2007 17:18
Oil up dipstick tube Fred85 OEM Tech Discussion 14 February 27th, 2006 08:02
