Old January 16th, 2008, 08:37
SnagglePuss's Avatar
SnagglePuss SnagglePuss is offline
Weld RK CA mounts instead of bolt
Think it would be better to skip the bolts and just weld the RK CA mounts?
Old January 16th, 2008, 08:49
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Re: Weld RK CA mounts instead of bolt
I'f you're worried about it do both... but at least use the bolts... why not?
Old January 16th, 2008, 11:31
builder builder is offline
I have not Confirmed, or I used a BAD email Addy
Use the bolts and sleeves.. and go ahead and do some stitch welds,bracket will never move after doing that.
Old January 16th, 2008, 11:48
RyanM's Avatar
RyanM RyanM is offline
x2 on bolting up then welding
Old January 16th, 2008, 12:41
troy6187's Avatar
troy6187 troy6187 is offline
thats what i just did on my mj. provides a lttle more peace of mind.
Old January 16th, 2008, 15:41
NCCherokee's Avatar
NCCherokee NCCherokee is offline
I think even if you didn't use the bolts, the sleeves at least would be helpful I think in reinforcing at least a small part of the frame. But if you've got the holes drilled, throw the bolts in there.
I'm installing some TNT stiffeners in 3 weeks, and I plan on getting the RK kitlater. Since it will be on top of the stiffeners, I can safely weld all the way around it, But i'm still planning on putting the bolts in.
Old January 16th, 2008, 19:23
With sleeves welded to the frame and tightened properly it will never go anywhere. stitch welding only can make them even stronger ! everyone wants bolt on.. i personally don't see a problem with welding on a 4x4 rig.people been doing it since 4x4's have been around.
M.O.R.E's "universal" weld on shock mounts 1bolt Modified Tech Discussion 4 January 21st, 2007 23:17
Weld-On Spring Perch, LCA, UCA Mounts (HOW?) XJoshua Advanced Fabrication and Engineering 9 October 5th, 2006 07:51
bolt and weld rear shock hoop? XJ99 Modified Tech Discussion 12 February 19th, 2006 19:37
weld the trac bar mount bolt tbear Modified Tech Discussion 8 August 23rd, 2005 00:30
AA bolt in Small Block mounts. TPI setup TPI MJ For Sale: Private Party Only. XJ ITEMS ONLY 1 August 8th, 2004 00:14
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
