Old December 2nd, 2019, 15:46
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
clayton 3 link cross, diy arms/mount?
figure Ill ask you guys before I find myself in a pickle.
Ive been toying with a long arm for a while and thus far. Im kinda liking the idea of something like the Clayton 3 link crossmember and building my own arms for hopefully saving some coin, and something fun to do.
the speedbump Im curious about is adding a press in johnny joint to the diff mount and building the upper arm to fit this, vs clayton welds a giant 3/8 bracket to everything on the pumkin.
Does anyone have a similar set up and do you think there would be enough separation to clear the driveshaft to use the JJ?
Old December 3rd, 2019, 17:31
Re: clayton 3 link cross, diy arms/mount?
Old December 3rd, 2019, 18:03
bajabronco bajabronco is offline
I know that with the Clayton kit they move the actual axle mount position over some more toward the center of the pumpkin, maybe that helps with stability? There might also be some concern with all the torque going to that one cast piece on the axle housing.
Out of curiosity, why are you deciding to go with a 3 link vs a 4 link ? Are you doing an engine swap and something interferes with the 4th arm ? Or are you just looking to save $$ and not spend money on the 4th arm? You could always look into just buying the 4 link cross member from someone like Ironman - https://ironman4x4fab.com/ . or the link brackets from Stinkyfab http://www.stinkyfab.com/sfr-jeep-xj...-arm-brackets/ . I am big proponent of the stability that a 4 link provides, both on and off road.
Old December 3rd, 2019, 20:24
I've talked with a few vendors on 4 links. Truly I would prefer this set up, but many of them have said I might need to modify exhaust to make the 4th link work.
I have the means to weld and cut but I have no way to shape exhaust so its just not for me. saving money is also part of the 3 link thought as far as diy arms. The cast mount also seems like a good bit for strength for a 3 link.
Expense wise I had a mind of what if I built my own cross member, but cost wise it hasnt been cheaper than a pre designed x member. SFR is awesome, but I like other platforms that use more length of the control arms that better level ride geometry. I'm not building a buggy nor draining the bank so Ironman is out hahaha. ultimately this is an effective goal to get away from fixed short arms and maybe to 35s, or at least a bit more lift on 33s, that would all be decided once Im able to adjust the arms.
I cant argue a 4 link is more secure, but I havent read anyone mention stability for 3 links, you have me curious?
Old December 3rd, 2019, 20:41
Heavyopp Heavyopp is offline
I like to build my own stuff too — it rarely saves money if you account for your time
That being said, I bought a 4 link setup from Ironman this summer — at the time I bought it I thought it was overpriced - even at the sale price — add the shipping and it gets even worse
Once I got it in hand I realized what I paid for — the pictures do not do his work justice — beefy is an understatement — the lower arms or “beams” are hard to explain without seeing and holding them
Anyway, I get where you are coming from — design and build to make you feel like your saving money — in the end it’s more about you made something yourself, full custom — problem is we aren’t getting any younger — takes me more time to design and build than I actually get using the stuff I’ve built
You just need to decide where your time is better spent — it’s only money...
Old December 3rd, 2019, 23:13
RCP Phx RCP Phx is offline
Might consider radius arms, I built my first set (on my 2000) about 18yrs ago.
Old December 3rd, 2019, 23:14
Here's the link.....
Old December 3rd, 2019, 23:16
One more try.... you might have to type it in.
http://s721.photobucket.com/user/apa...ry/Long%20Arms
Old December 4th, 2019, 03:27
SlowXj SlowXj is offline
I run the iro 3 link on my beater Cherokee and it is just as stable on road as my clean stock xj. With that said I only have a 3.5 inch lift. The iro kit does rely on the cast mount and I have had no problems in 2 years. The upper arm does have 2 bends in it to clear the floor at full stuff as well as the pinion yoke.
Old December 4th, 2019, 08:43
smokeyyank's Avatar
smokeyyank smokeyyank is online now
Jeepoholic
Really there hasn't been anyone that can truly say 4 link is more stable than 3 link. It really boils down what can you fit, what is your preference but above all how you build it. Each set up will have inherent differences based on what your doing. One of the nice things about a 3 link is that it's easier to mount the links where they'll fit, as opposed to a triangulated 4 link where the position of the mounts provides the amount of triangulation.
88 MJ, 4.0, 4wd, 3 pedals, Shortbed.
Mods; ACOS, quick discos, HD tie rod and a bitchin air fresher
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old December 4th, 2019, 08:53
Purely from a mechanical engineering standpoint, 3 link vs 4 link without triangulation with the addition of a panhard bar shouldn't make a difference. As they would have the same degrees of freedom. This isn't taking into account the very small amount of triangulation on the upper links though... As I don't think that would be enough to add anything to the pot.
Old December 6th, 2019, 11:49
I wanted to add that I thought about removing one upper arm or making it "wristed" but I never found a reason to motivate me to do so.
Old December 6th, 2019, 13:07
Is anyone running Clayton longarms?
Old December 9th, 2019, 07:35
Evan03 Evan03 is offline
Exhaust is easy to rout. By enxspensive shorts bends off ebay. Or just cut 22deg pies out of straight pipe to make bends. Alittle bit of welding but makes routing easy. Tack it all together remove then finish weld. Looks pretty damn cool to and is truly custom
Old December 9th, 2019, 21:21
lol this whole bit has me curious about redoing the down pipe, or map gas and bending out the dents, idk lol.
I found a good deal on goatbuilt JJs+tube insert/jambnut combos. Im trying to price out tube, be it square or DOM. Thus far one local distributor says it comes in 17ft length, w.t.h.? much more than I need...
I would prefer 2x .250" square lower tubing, 1.5x.250" DOM upper link, JJs and a 1/2" bolt cast mount press In JJ.
Im not sold on a cross-member, but I do plan on welding it to frame stiffeners one day.
still researching, Ill need more tubing qoutes to know whether ill get a better deal on pre built or not. Ruffstuff has a dom package at 186$ in 3ft sections. they have other cool deals, but im not interested in heims really, DD and all.
the search goes on
Is anyone here using Clayton 3 link & rear 4 link? josh9mile Modified Tech Discussion 4 June 25th, 2015 18:40
clayton 3 link and rear 4 link with under 6" of lift. josh9mile Modified Tech Discussion 11 August 17th, 2014 17:21
Clayton Xj rear 4 link arms an belly pan great-white NAC Classifieds 6 November 17th, 2013 00:52
Clayton longarms vs. Clayton 3 link AwesomeXJ Modified Tech Discussion 74 May 12th, 2011 21:41
