Old November 26th, 2019, 10:04
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: weld it or clamp it
we used a clamp on the alum steering on 4643 and never had a problem with it.
Old November 26th, 2019, 11:52
techno1154's Avatar
techno1154 techno1154 is offline
I guess a good quality clamp that fit properly would not be a problem.
I have one the RuffStuff offering that is used to attach the steering dampener ion my XJ. I would not hesitate to attach a steering ram for hydraulic assist to it. It is that well made and the fit (and finish) is second to none.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old November 26th, 2019, 12:00
cal's Avatar
cal cal is offline
We used basically this, but without the threaded hole in it, and welded our mounting tabs to it
https://www.ruffstuffspecialties.com/catalog/R1697.html
Old November 30th, 2019, 00:19
denverd1 denverd1 is offline
What tire size?
Locked front I assume?
Old November 30th, 2019, 06:43
RCP Phx RCP Phx is offline
Before I found my PSC clamp(same as Ruffstuff) I would just make one from left-over chromoly.
Old November 30th, 2019, 07:01
TRCM's Avatar
TRCM TRCM is offline
Only problem with that design is you can't install it without taking one tie rod end off......
Old November 30th, 2019, 08:03
Darn!!! But on the positive side, you can configure it any way you need it (as in double shear for a heim).
Old December 1st, 2019, 13:16
Evan03 Evan03 is offline
I wouldn't trust welds on aluminum in high stress area they will fail.
Old December 1st, 2019, 14:26
srb531 srb531 is offline
Originally Posted by denverd1 View Post
What tire size?
36" tire, locked frt.
weld or clamp? kenny schmitt Modified Tech Discussion 10 March 6th, 2011 17:45
Hose clamp falcon556 OEM Tech Discussion 8 January 26th, 2008 12:41
steering box clamp Redcbr007 Modified Tech Discussion 7 September 6th, 2004 00:58
Getting clamp off tb hose? ZachMan OEM Tech Discussion 3 February 15th, 2004 20:03
One C-clamp down, how the H#LL do I get these bushing sleevves out???? Safari Ary Modified Tech Discussion 4 May 9th, 2003 07:29
