Old November 23rd, 2019, 14:08
srb531 srb531 is offline
weld it or clamp it
attaching ram assist to a aluminum tie rod,whats the recomendation here ? tie rod is 1 1/2" od
Old November 23rd, 2019, 14:21
TRCM's Avatar
TRCM TRCM is offline
Re: weld it or clamp it
This is the route I'd go...used it for my steering stab on my 1 ton steering setup....works very well
https://www.ruffstuffspecialties.com/catalog/R1697.html
You could use 1 side to mount the stud for the ram, and the other side could be used like a set screw for additional clamping (altho I'm not sure it'd be needed).
Old November 24th, 2019, 13:06
denverd1 denverd1 is offline
i'll be welding mine to a steel tie rod
Old November 24th, 2019, 16:19
as i would to, if i had a steel tie rod, but my steel one ton rod bent so bad it couldnt be rebent w/in reason to straight so i went w/ alum. now. question is would it be adviseable to weld steel or alum. brackets to a alum. tie rod ?
Old November 24th, 2019, 16:58
alum brackets may make sense then TIG it
Old November 25th, 2019, 07:17
Heavyopp Heavyopp is offline
I wouldn't weld it -- What is the alloy of the tie rod? -- how about the bracket?
Clamping to aluminum just makes sense here
What is the worst that happens, you clamp it and your clamp moves -- if it doesn't hold then you need to weld it
Old November 25th, 2019, 07:47
why is welding is the backup plan rather than the plan? curious why you wouldn't do it right the first time...
Old November 25th, 2019, 10:05
XJlimitedx99 XJlimitedx99 is offline
What alloy is the aluminum? Not all aluminum is weldable.
Old November 25th, 2019, 11:24
bajabronco bajabronco is offline
I had a buddy that used a clamp for his hydro-assist, and even though the clamp was as tight as it would get, when we were on the Rubicon it continued to rotate. If you go the direction of using the clamp make sure there is something that the clamp can grip to vs just the smooth tie rod. Lay some small beads down to create some ridges, or cut some groves in it, so the clamp is not having to grip to a completely smooth surface.
Old November 25th, 2019, 13:05
i will start w/ a clamp & see how it goes, if it moves maybe add a couple tack welds on each end of the clamp.
Old November 25th, 2019, 13:08
TRCM's Avatar
If you use that clamp, you can machine/grind a small flat spot on the bottom half and use the 2nd threaded mounting point as a 1/2-20TPI set screw........
And follow the directions on the website for hydro assist
Old November 25th, 2019, 18:34
Welding to unknown aluminum alloy is tricky — do we know the alloy
Are any of the parts hardened? The heat from welding will change that
Personally I wouldn’t want that small “hot spot” on my tie rod could easily cause a brittle spot
Here’s a thought — are we talking an iron man or stinky fab aluminum tie rod — give them a call — I’ve spoke to Andy at iron man before and I know he’d be happy to talk about connecting options on one of his aluminum tie rods — I’m sure it would be the same with Dallas over at stinky fab
Old November 26th, 2019, 03:56
its a stinky fab rod. thx for the tip.
Old November 26th, 2019, 04:39
That's 7075 aluminum which is not weldable (with traditional techniques). The composition of the alloy makes it develop super brittle areas around the circumference of the weld and ultimately will crack every time.
Its unfortunate because 7075 is a great alloy.
Old November 26th, 2019, 07:13
make sense, thx for the explanation
weld or clamp? kenny schmitt Modified Tech Discussion 10 March 6th, 2011 17:45
Hose clamp falcon556 OEM Tech Discussion 8 January 26th, 2008 12:41
steering box clamp Redcbr007 Modified Tech Discussion 7 September 6th, 2004 00:58
Getting clamp off tb hose? ZachMan OEM Tech Discussion 3 February 15th, 2004 20:03
One C-clamp down, how the H#LL do I get these bushing sleevves out???? Safari Ary Modified Tech Discussion 4 May 9th, 2003 07:29
