Old August 17th, 2010, 19:26
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Re: Beginning of 1993 Cheromanche build
That looks pretty good and I was wanting to do the back doors like that with the full size window, but if you graft the doors together to have the rear door lines line up with the cab the shape of the window would prevent it from rolling down. So I guess I'm going to keep the little window in the back of the door and have the front of it roll down all the way. I will eventually update it to 97+ doors and front end as I want the windows to roll down all the way on the front and just love the look of the front end.
Old August 18th, 2010, 01:15
Kittrell's Avatar
Kittrell Kittrell is offline
I always figured on grafting the back half of the front door to the front half of the back door. Make sense?
Old August 18th, 2010, 01:16
Kittrell's Avatar
Originally Posted by kastein View Post
yep...fairly certain the guy who did it is the one who just posted it.
That is correct.................
Old August 18th, 2010, 03:30
Yah that's what I'm going to do is cut off the back of the manche door and graft it over the rear doors of the XJ. Unfortunately the way the top of the rear doors points towards the back prevents the rear window from being a 1 piece window. So I'll use some 1/4" plexi or lexan to reshape the small window in the back doors when I know the shape of them. Then I'm going to have to custom make an interior door panel as the stock rear door would have big openings and I dont' think the front door would fit on the rear.
Old August 18th, 2010, 20:32
Kittrell's Avatar
Get a custom piece of glass cut.
Old August 18th, 2010, 22:24
shelbyluvv's Avatar
shelbyluvv shelbyluvv is offline
XJ glass is beveled. To have just one piece bent and cut is over $1000. I have researched all of this in depth.
You have to pay to have a custom mold made and the glass must then be tempered. It get pricey really quick!
Old August 19th, 2010, 00:07
Kittrell's Avatar
Anything worth doing, is worth doing right! Come on Bo, you know I'm a perfectionist. I'd spend the money...............
Old August 19th, 2010, 07:15
Stallacrew's Avatar
Stallacrew Stallacrew is offline
I am confused.
To make the rear door, since you will have to splice two doors together anyhow, why dont you use the back of a front door and the front of a back door and make it the length of the front door if it were cut top to bottom at the triangle. Use all the stock stuff for the front window. That way the whole window rolls down....is that not feasible?
Old August 19th, 2010, 07:26
Wil Badger's Avatar
Wil Badger Wil Badger is offline
Because it will actually make a trapezoid with the top of the window being larger then the bottom. It would not roll down. Take a closer look at the rear of the Comanche door. You will see the rear of the door slopes back. The front of the rear door is almost straight up and down.
Old August 19th, 2010, 08:05
Stallacrew's Avatar
Oh
Gotcha.....must have missed that.
Old August 25th, 2010, 16:36
Was able to get home from the trip early and decided to take a couple days off work. Spent most of the day working on the rig and got the roof of the manche chopped off, got the cut lines straightened out and calculated the rear door size. Pushed both halves together and they line up beautifully just have to mold in a couple of small fluctuations like the lip at the outside of the rockers and such. Tomorrow will work on cutting out floor of the manche and part of the XJ as the pass. side had alot of rust then get the frames and rockers prepped for welding. Will definately have to go with a 2 piece driveshaft as it measures around 80" long, will determine and build cross member after everything is put together. Rear door will end up being about 36" long which is about 8" longer than the original size which will allow for plenty of leg room in the back for anyone.
Old August 25th, 2010, 16:43
dick.breakey dick.breakey is offline
with all that room i could completely sprawl out. sounds nice.
Old August 25th, 2010, 17:07
There's a pic of it pretty close to the size it's gonna be. Will get more detailed shots tomorrow.
Old August 25th, 2010, 17:13
tribalmentality's Avatar
tribalmentality tribalmentality is offline
you should get some two door cherokee doors, and then build a "fixed" extended cab, and trash the four door idea. judging from the previous atempts and photoshops, the four door cherokee doors just dont flow right to me. just my $0.02
Old August 25th, 2010, 17:16
oh, and i understand the b-pillar issue, but you've cut it up this much... why stop now! lol
Tubewerk- the beginning... bcmaxx Modified Tech Discussion 10 April 21st, 2010 22:17
Gun Certification is Beginning Ecomike Political Discussion Zone 28 August 10th, 2009 22:11
1993 2 door build opinions? Fromagnon Modified Tech Discussion 8 April 30th, 2008 22:49
beginning exo Fullsizexj Modified Tech Discussion 14 January 4th, 2004 02:09
