Old December 15th, 2014, 18:16
donthelegend donthelegend is offline
Re: Best type of LED lights for driving
Lumens measure total light output. Candlepower is a measure of light output at a certain angle. Lumens apply to all lights, not just LEDs.
Candlepower is directly related to lumens, but can be fudged a bit based on where you take your measurements.
Old December 16th, 2014, 23:15
Racer~X's Avatar
Racer~X Racer~X is offline
Originally Posted by crazymaci View Post
Now that is solid info right there. Basically robbing switched power from the factory headlight system to switch on the relays, and supply direct battery power to the new lights. Makes sense, I'm going to run a main power from the post to this fused gang section, will also be able to run my onboard air pump as well
I need a fuse (or breaker) box like that, BTW I have the same HF Tap & Die set.
Originally Posted by mechbullxj View Post
Does anyone know the difference between Candlepower and Lumens, when rating brightness of a lights output? Does Lumens apply to LEDs only? I'll post a few pictures of a Baja Design 10" rated at 4200 lumens @ 100% power output.
Many LED's are rated in MCD - mini-Candelas, It is a measure of brightness - in a single direction, Lumens measure total light output. i.e. a 40-Watt lightbulb should put out a good 400 Lumen (probably similar to a 5-Watt LED)
Converter, and info:
http://led.linear1.org/lumen.wiz
More info:
http://www.compuphase.com/electronics/candela_lumen.htm
Old November 14th, 2019, 14:02
macidgit's Avatar
macidgit macidgit is offline
I can't help with lumens but I can say I have Hella headlight housings w/ leds in one xj and IPF housings w/ leds in another. Each have direct from battery power using relay. Excellent excellent patterns and output from both using recent design led bulbs is terrific. Best non - drive train upgrade ever.
Steve C., Cincinnati, Ohio
~ Member #2896 ~
2000 Limited, ATK 4.7 Stroker, AW4, D30/Ford 8.8, 4.10's, e-locker /trac-lok, 265/75-16 Duratracs, 4.5" RE w/ Bilsteins, C-Rok bumpers F&R
Old December 1st, 2019, 19:39
tm8chris tm8chris is offline
What brand of LEDs did you get? I'm planning to upgrade mine.
Old December 11th, 2019, 09:43
MG2000XJ's Avatar
MG2000XJ MG2000XJ is offline
Does the H4 LED conversion retain the high/low beam functionality?
Off road lights as driving lights? coldoath Modified Tech Discussion 23 May 11th, 2011 17:34
Driving Lights Bdiddy11 OEM Tech Discussion 7 November 3rd, 2010 16:37
Driving lights FlexdXJ MWC For Sale/Wanted Forum 9 April 9th, 2010 12:54
55W Driving/Fog Lights Cherikon Modified Tech Discussion 18 September 8th, 2006 19:59
aux driving lights 97XJ Modified Tech Discussion 3 November 6th, 2004 18:29
