Nckthebeast456
- North bend
Whitish brown crusty resedue on all 6 plugs causing missfireing and rattle at high rpm, what are the possible causes of this i know white plugs indicate a lean fuel/air ratio, i replaced the map sensor and the fuel filter it helped the rough idle but still fouling plugs. My question is where should i start looking? o2 sensor? Fuel pump? Vacuum leak?. My jeep also has no EGR valve or emmisions all have been blocked out or deleted my jeep also has no cat its a full straight pipe, any sugestions would be awesome! Thanks
