lordoeuf
- Vancouver Island
Could someone let me know how to disable the engine so that it will not start when cranked? I've seen this instruction repeated from multiple sources when it comes to replacing the steering gear box and priming the system with new PS fluid. My guess is that there is a relay or fuse I need to pull from the power distribution centre (PDC), but which is it?
The PDC cover lists: 56038363AB
FUEL PUMP
STARTER
ASD
COOLING FAN
ABS LIGHT
FOG (DRL ONLY)
FOG LAMP
A/C CLUTCH
HDLP SW (30A)
BLOWER (40A)
COOLING FAN (40A)
BATTERY ACC (50A)
IGN RUN/START (40A)
IGN ACC/RUN (40A)
ABS SOL (20A)
ABS MOTOR (40A)
HBL (30A)
STARTER (20A)
A/C CLUTCH (20A)
If I were to guess, either pull IGN RUN/START (40A) or IGN ACC/RUN (40A). Maybe ASD? I'm not sure what HDLP stands for.
Thanks!
FUEL PUMP
STARTER
ASD
COOLING FAN
ABS LIGHT
FOG (DRL ONLY)
FOG LAMP
A/C CLUTCH
HDLP SW (30A)
BLOWER (40A)
COOLING FAN (40A)
BATTERY ACC (50A)
IGN RUN/START (40A)
IGN ACC/RUN (40A)
ABS SOL (20A)
ABS MOTOR (40A)
HBL (30A)
STARTER (20A)
A/C CLUTCH (20A)
Thanks!
