Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > ZJ and WJ Grand Cherokees (1993 - 2004)
ZJ and WJ Grand Cherokees (1993 - 2004) Technical forum for the classic ZJ and WJ Grand Cherokees.
Old May 21st, 2019, 08:41
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Re: Project Potimus
Originally Posted by trippled View Post
We're you welding outside? Even a gentle breeze can blow your shielding gas away and give you porosity. Others aren't too bad tho. Mig spatter is pretty normal I'd say.
Yeah I was. Guess that would explain it then. I wasn't able to get a good pic of it but when doing the exhaust that was tricky. I think a large part was from welding upside down. I just couldn't get a good bead started. We also changed the spool to a smaller gauge wire and I don't think I had the welder set up right. We turned down the purge and wire speed but when I was upside down beads just did not like to stick.
88 MJ truggy, 4.0HOybrid AX15, NP242 **Being built**
Mods: D44 w/ 4.30's, ARB front and Auburn rear, 33's
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old June 24th, 2019, 12:46
smokeyyank's Avatar
Jeepoholic
Re: Project Potimus
Replaced all the steering this past weekend. The TRE's were in worse shape than I thought. They had 0 resistance when it came to moving them around. Also found one of the control arms was a little loose so tightened that up along with the track bar. I also corrected some issue with the steering stabilizer. I went with the MOOG trail boss and it didn't have all the correct hardware when I put it in. A lot less noise on the road but still not the smoothest. I will admit some of the roads around here are really bumpy and most of the time it's not a bad ride but fn a it's loud compared to my MJ, and that's stock for the most part with stuff that hasn't been replaced in I don't even know how many years. I'm going to air down the tires a little as I think that is another thing causing some issues. I'm running load E which is overkill (I know, but wanted 10 ply tires) and I think I need a little more cushion and not as much air.
I also started to finish up some of the stereo. I bought all new speakers, nothing special just some basic Kickers. Only thin I really changed was I put 3.5" in the dash vs the stock size. Few little cuts but they fit just fine. I'm not happy with the way to deck looks though. I moved up to a double din and the fitment is garbage. I'll take a pic later but it just looks terrible.
Old vs New
My "helper" for the day
04 WJ, 4.7HO
Old September 16th, 2019, 13:35
smokeyyank's Avatar
Jeepoholic
Re: Project Potimus
Well it's been a while....not a whole lot to report other than I finally got a free weekend to work on somethings. One of the things I've been wanting to do was freshen up the headlights.
They've been rough and at night can't see $h*t especially in the mountains where there is already limited light.
Process was pretty easy and I like the results.
04 WJ, 4.7HO
Old September 25th, 2019, 13:38
PacificEd's Avatar
PacificEd PacificEd is offline
Re: Project Potimus
What did you do to freshen them up and make them clear again? I need to clean some headlights up in my stable.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Current SEC Chapter Treasurer 2021-2022
Old September 27th, 2019, 09:44
smokeyyank's Avatar
Jeepoholic
Re: Project Potimus
I just used this kit.
https://www.amazon.com/Meguiars-Two-.../dp/B01M75GUJB
The sylvania kit is better but I couldn't get it shipped to me.
Took about 45 minutes. Only advice is use both of the scuff pads. I only used one because there is way more cleaning and spray than needed and wanted to do my wifes car. But there is a slight difference between how "clean" the first vs second side is. So you could probably find some scotch bright pads to do more than 1 set.
04 WJ, 4.7HO
Old June 14th, 2020, 07:24
smokeyyank's Avatar
Jeepoholic
Re: Project Potimus
Well been a while lots happened.....dropped a valve seat so engine had to be rebuilt again. That took 6 months to get back. During that processes also replaced axle seals and put the lunchbox in. Also put a new ironman diff cover on and had to modify the sway bar and put spacers on the reduce contact. Fixed a stereo issue and got rid of an annoying crackle along with replacing the double din faceplate. Had a really bad leak at avtranny line and the temps havent been doing good been 200+ most days. So I bypassed the rad to a standalone remote cooler. Temps stay about 150-160 and doesnt leak anymore. Next up is fixing an exhaust issue and getting so 4awg battery cables.
04 WJ, 4.7HO
Old July 2nd, 2020, 16:43
smokeyyank's Avatar
Jeepoholic
Re: Project Potimus
Took the junk out to mess around with the lunchbox. Love it offroad, on road........not so much.
Here's my cute poser shots.
04 WJ, 4.7HO
Old November 22nd, 2020, 11:26
Kittrell's Avatar
Kittrell Kittrell is offline
Re: Project Potimus
Curious, I loved our '04 Overland around town. What's the nag?
Old November 24th, 2020, 10:15
smokeyyank's Avatar
Jeepoholic
Re: Project Potimus
The lunchbox is the nag. Without it it was fine, no issues, but the thing is loud. I had a lunchbox in the XJ and wasn't that bad but in the WJ it honestly is annoying AF. The WJ got retired from DD duties so don't mind it as much but more than likely I'm going to take it out or swap in a 9".
04 WJ, 4.7HO
Old November 24th, 2020, 17:31
Kittrell's Avatar
Re: Project Potimus
Why not a JK 44 with elocker? Perfect width and bolt pattern for the WJ.
Old November 24th, 2020, 20:36
smokeyyank's Avatar
Jeepoholic
Re: Project Potimus
That's another thought. Guess it just depends on cost.
04 WJ, 4.7HO
Old November 25th, 2020, 11:33
Kittrell's Avatar
Re: Project Potimus
Just need to look around, they are out there. If you get the non rubicon housing, you can save a bunch (no elocker of course but endless options). I sold one a month or so back for $200 (bare housing).
Old November 26th, 2020, 21:27
smokeyyank's Avatar
Jeepoholic
Re: Project Potimus
Yeah then theres the gremlin in the back of my mind keeps saying just say f it and go tons.
04 WJ, 4.7HO
Old November 27th, 2020, 14:16
Kittrell's Avatar
Re: Project Potimus
I mean, I won't try and talk you out of that.
Old December 5th, 2020, 17:47
smokeyyank's Avatar
Jeepoholic
Re: Project Potimus
Snagged some new bumpers from trailforged. Front was a black Friday deal and rear was a lucky CL find. Hoping I can get them intalled before next wheeling season but not banking on it. I'll need to fab a tire carrier for the rear but super stoked to finally get them.
04 WJ, 4.7HO
Project XJ WUS Renegade0401 NorthWest Chapter 19 January 1st, 2015 14:59
My next project. BoringDave NorthWest Chapter 9 July 6th, 2012 15:25
Looking for project MJ dave92cherokee SEC For Sale / Wanted Forum 17 June 2nd, 2010 06:35
Project 100$XJ and Project JEEPSPEED AZXJ Arizona Chapter 23 August 23rd, 2007 13:57
91 4dr project 33s, 91 4 dr project stock Rockhound For Sale: Private Party Only. XJ ITEMS ONLY 1 May 8th, 2007 21:13
