Old March 13th, 2019, 17:24
FlexJ17 FlexJ17 is offline
Gearbox play when turned all the way
My steering box when turned all the way to the left or right, has alot of rotational play(not up and down) but when the pitman arm is centered the play isn't noticeable. I'm talking 1/4" To 1/2" of play but only when all the way to left or right.
Old March 14th, 2019, 08:44
denverd1's Avatar
denverd1 denverd1 is offline
Re: Gearbox play when turned all the way
did you check your mounting bolts? any reinforcing done up front? front locked? tire size?
had the pleasure of replacing my steering gear about halfway through a trip to Arkansas a few days ago.
the bolts are 7/16" with 14 threads/inch. I needed 4" bolts because my spacer is a tad thicker than most. it's an incredibly crappy design. Will be going hydro assist soon.
If you pull it off, check the condition of inner frame rail. if this has been an ongoing issue, you're frame rail is likely deformed and allowing it to flex when you apply pressure either direction. really need at least 3/16" steel on outside, box the bottom in with some angle and you have some chance of it working ok. second gear I've put on it. I'm locked on 33's so it was matter of time.
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old March 14th, 2019, 11:54
8Mud's Avatar
8Mud 8Mud is offline
Check your ball joints.
Rock Pile, turned bashing, turned ZJ thread Brett M Intermountain Chapter 125 December 18th, 2007 23:17
X play in track bar=Y play in steering wheel Timber OEM Tech Discussion 4 March 30th, 2006 05:40
gearbox FUNKYGREG OEM Tech Discussion 3 December 16th, 2005 09:57
Steering Gearbox Cruzin Illusion Modified Tech Discussion 14 June 29th, 2005 05:50
AGR gearbox leak AZcrawler Modified Tech Discussion 0 October 25th, 2004 12:23
