Old March 8th, 2019, 13:35
FlexJ17 FlexJ17 is offline
Random Stalling issue
Just recently my 2001 jeep cherokee, (normally on the first start of the day) will start fine but as soon as i drive to the first redlight and sit for a minute, the rpms will increase slowly as if i was slowly pressing the gas and then i will go to accelerate and it goes a few feet then completely shuts off, then i'll try to crank and crank but it wont start, cranks fine, but no start. sometimes it wont start for 10 minutes sometimes 15, sometime it will start a minute after it dies, but each time with hesitation (i have to crank and give it good gas), then it will start up and drive fine. there always is the warning of the rpms raising first, thats how i know its gonna happen, and always at a stop.
Old March 8th, 2019, 14:15
Re: Random Stalling issue
i would also like to add, just yesterday i got a p0118 code for coolant temp sensor circuit 1 being too high, and a couple times the temp gauge just wouldnt work, im thinking maybe that could be the problem, im reading that a bad temp sensor could cause my problem
Old March 8th, 2019, 15:01
JeepNoob JeepNoob is offline
I'd start by replacing the ECT sensor. Almost all ECT sensors are a negative temperature coefficient type, meaning as the engine warms up, the resistance decreases, resulting in more voltage reaching the PCM. On a cold-start, the PCM just wants to dump fuel to the engine since less of it is going to vaporize (similar to an old-school choke.) The ECT sensor is also the only sensor the PCM pays attention to to make fuel adjustments when first started and as the engine warms up. So, in a nutshell-
Engine start-up/warmup: Lots of ECT sensor resistance, low voltage to the PCM, lots of fuel. (Open-loop engine mode.)
Engine warmed up: Less ECT sensor resistance, higher voltage to the PCM, less fuel. (Closed loop engine mode.)
Old March 8th, 2019, 15:06
Edit: Minor brain fart, it's possible (but I suspect highly unlikely) that the ECT sensor circuit is shorted to voltage somewhere. To verify this, disconnect the ECT sensor. Measure the voltage on both terminals of the connector with the key on. One should have voltage, the other should not.
Old March 8th, 2019, 15:29
Heavyopp Heavyopp is offline
ECT = Engine Coolant Temp???
Old March 8th, 2019, 15:36
thanks jeepnoob i will go ahead and test that with a multimeter, and also gonna go buy another temp sensor. embarrasing holding up traffic because my jeep randomly died and wont start lol
Old March 8th, 2019, 18:30
SleeperXJ's Avatar
SleeperXJ SleeperXJ is offline
This sounds like what my 99 did when the Crank Position Sensor (CPS) went out.
You might want to check CPS if ECT checks out Ok.
Old March 8th, 2019, 21:43
Yes, ECT= Engine Coolant Temperature.
Test with DVOM FIRST. Key on, if voltage on both wires, you're gonna have to start chasing a short to voltage. If one wire has 0 volts, and the other has ~5 volts, suspect a faulty ECT sensor.
And yeah, I know it can be a PITA. My '96 once had a problem where it would only stall at low engine speeds. Once it got running faster, the problem would go away. Long story short, I found my pickup coil in the distributor COATED in oil. How it got in, I haven't a clue, but I suspect centrifugal force from higher engine speeds was causing oil to sling off the pickup coil target and vice-versa. A new distributor and gasket fixed the problem..
Old March 9th, 2019, 05:15
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
If you have known fault or failure, fix that first. You cannot properly diagnose and trouble shoot problems when you have the potential of multiple causes for the symptoms.
Solve the P0118, and then see what happens. If the stalling persists, suspect the Crankshaft Position Sensor, the Idle Air Controller, and the Throttle Position Sensor and their wire plugs and wire harnesses. Test the sensors, check wire continuity of the wire harnesses, and inspect the wire plugs for corrosion, or pushed back/bent wire plug pins.
P0118 JEEP - Engine Coolant Temperature Sensor Circuit High
Possible causes
•Faulty Engine Coolant Temperature (ECT) sensor
•Faulty engine coolant thermostat
•Engine Coolant Temperature (ECT) sensor wire harness is open or shorted
•Engine Coolant Temperature (ECT) sensor electrical circuit poor connection
•Low engine coolant level
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old March 9th, 2019, 17:16
lawsoncl lawsoncl is offline
I vote for the crank sensor as well for the stalling. As they start to fail, the signal can get weaker as it warms up and the signal strength is also rpm dependent.
Old March 9th, 2019, 20:10
changed the ect sensor, p0118 code has not came back, gauges functioning correctly,no stalling so far, but then again ive only driven it once.
Old March 11th, 2019, 16:29
Probably got it licked then, but keep an eye on it. How long was this drive?
Old March 12th, 2019, 04:08
Rick.rob Rick.rob is offline
My 01 did the same thing, over the summer. I changed the temp sensor and has been fine ever since.
Old March 13th, 2019, 17:30
Well it's been a couple days now, and no problems whatsoever so it was a bad sensor
Old March 13th, 2019, 22:03
SleeperXJ's Avatar
Thanks for reporting your success. Feedback will no doubt be helpful
to someone down the road.
Random stalling 96killgore OEM Tech Discussion 3 June 20th, 2018 20:23
Random stalling issue. runs great, then just dies. tayman OEM Tech Discussion 30 October 2nd, 2014 19:58
Random stalling issue wishihaddaxj OEM Tech Discussion 4 November 20th, 2011 06:56
Stalling out and studdering random!!!!!! bigboyslimjimbo OEM Tech Discussion 8 April 2nd, 2009 11:07
Random Stalling shanecooley OEM Tech Discussion 0 February 21st, 2007 04:27
