Old September 30th, 2017, 09:14
MagicNelson's Avatar
MagicNelson MagicNelson is offline
Re: Long Arm Upgrade - Opinions?
I've been happy with my Clayton radius setup. Been running it for 3 years with no issues. It's easy to convert to a true 3-link in the future as well if you ever wanted to.
Old September 30th, 2017, 09:36
Faz95XJ Faz95XJ is offline
Originally Posted by burntkat View Post
Regarding the Clayton's kit. Yes, this... but make sure your buddy is a good weldor. Certification isn't required, but more than just posession of a welder is.
Most of the people that I know only have a welder. They don't have much experience. That's why am trying to avoid welding. But I'm still a ways away from doing this, So the hunt continues for a welder and an experienced welder.
Old September 30th, 2017, 10:24
Serious Offroad's Avatar
Serious Offroad Serious Offroad is offline
NAXJA Supporting Vendor
Check your PM's
Old September 30th, 2017, 16:55
kcox506's Avatar
kcox506 kcox506 is offline
Well lets go there. Ironman4x4fab has a 3 and 4 link system that is bolt on AND weld on. Not only bolt on. Has to be both. Anti-dive numbers adjustable from 75% to 120%.
Ironman4x4fab Marketing Manager
2000 XJ ~4.5" '06 4.0
LP44 w/Rubi Air Locker & 8.8 ARB
231 w/ beefy stuff
Old September 30th, 2017, 19:00
TRCM's Avatar
TRCM TRCM is offline
Hmmmm...now that looks interesting..................not seeing it on their site tho........
Old September 30th, 2017, 19:02
Kittrell's Avatar
Kittrell Kittrell is offline
That's a lot of hardware hanging on just the factory nutserts.
Old September 30th, 2017, 21:00
Heavyopp Heavyopp is offline
I saw this in the vendors section a few days ago -- there's a video but not much info
Hey Kcox506 - Marketing guy for Ironman fab -- I for one would love to hear more about this -- It certainly looks like it has potential -- How about some real details?
Might not be the right place here but...
Old October 1st, 2017, 08:09
kcox506's Avatar
As I had said, its weld and bolt on only. You're most certainly correct.
40" lowers, 36" uppers.
All four links in place with less than 30 degrees of link intersect
Adjustable Separation and adjustable link lengths (allows you to dial in your Ant-dive)
Barnes Enduro Joints at the frame, Clevite at the axle (any joint combo possible really)
Lower links are .281 wall DOM and Upper Links are 1.25" solid 1045 CRS.
Rear 4 link already in the works that is an extension of the front. Give it a few weeks.
231 w/ beefy stuff
Old October 1st, 2017, 18:55
So what is the minimum amount of lift needed to run a long arm/4 link
I assume the drivers side upper axle mount is the determining factor -- the cast mount in the diff housing
Are really good bump stops a must?
Old October 2nd, 2017, 06:22
burntkat burntkat is offline
NAXJA Member #1145
Time to learn to weld. Gain a skill and it's more or less a license to print money, or at least fix your own junk around the house. I've used welding in everything from vehicles to furniture.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 2nd, 2017, 06:24
XjNick95 XjNick95 is offline
Lots of YouTube how tos, a lot of scrap metal and start burning away!
Old October 5th, 2017, 14:10
Gonna muddy the water here a bit ...
Given the limited amount of wheeling i actually get to do, and seeing that CavFab is running some sales right now, would it be reasonable to remove the RE drop brackets i am currently running with fixed LCAs and go with CavFab Stage 2 adjustable LCAs?
Old October 5th, 2017, 14:31
in4aride's Avatar
in4aride in4aride is offline
Originally Posted by XjNick95 View Post
Check out the B Lee's kit. several friends of mine run it with zero issues, its some what similar to the Cav-fab kits. it uses 3 bolts per side to connect to the frame. apparently there is a nutsert in the frame that needs to be drilled out and tapped and its ready to rock and roll. I have my kit setting in my basement, and its heavy as all get out!
https://bleesoffroad.com/collections.../3-link-system
Cavfab seems like a good set up.
Or make your own
Grab a gear, let's go.
Old October 5th, 2017, 15:42
RCP Phx RCP Phx is offline
Nope, but for just a few dollars more you could bet the TNT set-up!
Old October 5th, 2017, 15:53
TNT long arm or adjustable LCAs?
27 or 30 spline for Front Axle Upgrade? Opinions wanted! thebyus Modified Tech Discussion 31 October 1st, 2014 13:03
iron rock long front long arm upgrade: ZJ grandrunner SoCal For Sale 9 April 24th, 2010 21:30
Opinions on my long arm wheelinscott Red River Chapter 45 March 8th, 2010 14:23
Shock Upgrade Opinions MGrobe Modified Tech Discussion 4 August 4th, 2005 08:35
