Can anyone confirm D30 cover bolt size and length? 5/8 X 5/8 or 5/8 X 1/2? 3/4 length if you are using a guard? Or is it an M metric?? Don't want to pull a top bolt and do the "compare" thing.
5/8?....bolts are sized (except for the antiquated British Wintworth sizes) by the nominal diameter of the bolt shank, not the head.....in the case of D-30 cover bolts...they are either 5/16 USS by 1/2 or maybe 8mm std. (maybe 1.25threads per mm?) by 15mm or so....I have never needed to check for sure.
