cykaaro
- ontario, canada
One of my valve cover bolts is broken. I pulled out the bolt, or rather what's left of it, and the other half is still in the head. How do I get this thing out so I can replace the bolt?
jblaze5779 said:You can buy tap sets at sears they come in different sizes, basically jsut a backwards drillbit. the inside of the bolt should be soft.
Last time I did it I punched a divit in the top of the broke off bolt with a small punch and then put the tap in the divit and hit it lightly a couple times with a hammer and then attached the drill, then just reverse it out.
RyleyF said:Meh, there's like 40 valve cover bolts anyway, is one really that big of a problem?
It's not a big problem if you don't mind a leak where the one bolt is missing/broken.RyleyF said:Meh, there's like 40 valve cover bolts anyway, is one really that big of a problem?
cykaaro said:Will check the Sears up here and see what they have. It'll have to be a pretty small one though. Hoping it comes out without problems.
jblaze5779 said:the one that I used was very thin, looked exactly like one of those skinny wood drillbits
a steady hand is really all you need
