The D30 on the CJs have the pumkin on the right side and have the 5 on 5.5 or 5 on 5 (cant remember)lug pattern.. My Question is basically the axle is identical to a Hi pinion XJ (pumkin on drivers side) D30 but just flipped, Can you take the wheel hub bearing assembly from the XJ D30 5 on 4.5 and bolt it to the CJs D30 axle to change the bolt pattern?
