Old April 1st, 2005, 17:41
sictruck sictruck is offline
Checking PCM
hey guys is there a way to check the PCM in my 92xj. I think its bad. I've been having starting problems ever since i did a engine swap. and the PCM would be the last thing to change.
Old April 2nd, 2005, 17:18
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Re: Checking PCM
As far as I know, the only way to check the PCM is to replace it, if it hasn't thrown any codes, but it's pretty unlikely that this is the problem if it hasn't. If you're not getting any codes, and if it's running well once it starts, then it probably isn't the PCM.
Can you give some details on what the starting problem is?
Note, I might be slow in responding. I'm visiting relatives, hijacking my brother-in-law's computer, and may not get as many chances to log on as usual.
Old April 2nd, 2005, 20:49
Alaska_Muddin's Avatar
Alaska_Muddin Alaska_Muddin is offline
Re: Checking PCM
I agree... Everytime I had starting problems in mine it was because of the CPS. I would check that out and make sure the wiring didn't get pinched during the engine swap.
Need a PCM connector pin location diagram. TheRasper OEM Tech Discussion 4 December 19th, 2004 12:18
wanted 97 PCM Kejtar Wanted: Private Party Only 3 September 2nd, 2004 08:49
NEW guy Checking in UNDER CONSTRUCTION Non-Tech / Off Topic 2 August 30th, 2004 09:40
Is the Powertrain Control Module (PCM) and the ECU ssnsltd OEM Tech Discussion 6 July 31st, 2003 17:46
Bad PCM? Deyman OEM Tech Discussion 8 July 16th, 2003 17:28
