Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > The Crossover Jeeps > The New Cherokee KL (2013 - Present)
The New Cherokee KL (2013 - Present) Technical forum for the new crossover Jeep Cherokee.
Old April 22nd, 2020, 21:34
Wiser's Avatar
Wiser Wiser is offline
Post 2” Lift for KL
Hello members out there that are untested or curious about lifting the Jeep Cherokee KL. My KL is the Latitude AD1 platform. I Recently purchased a 2” lift and was able to gain an actual 2” of Lift clearance for some larger tires. I was able to fit 245/70R17 Milestar Patagonia ATWs without any inner fender trimming. The lift was an easy install and took 3hours. The only drawback about lifting this Jeep is you cannot adjust the camber on the front of the Jeep. Jeep didn’t design the front end of this with a whole lot of adjustment in mind or would think people would want to lift a crossover. Unfortunately with a 2” lift, the front camber will be roughly at +1.5* camber. It’s not terrible but time will tell how my tires will wear in the front. When it comes to rear alignment, it was adjusted into spec with no problems. I will be posting before and after pictures when I find a new photo hosting. I’d thought I would share since this is a new platform with not much info out there.
https://lh3.googleusercontent.com/Cf...2cyJ6bPx=w2400
Lifted^
Old September 14th, 2020, 18:14
Calvin Bnvds Calvin Bnvds is offline
Re: 2” Lift for KL
It looks nice, its not that exaggerated but you can definitely see the difference.
Old May 18th, 2021, 08:34
tonytech tonytech is offline
Re: 2” Lift for KL
What brand of lift kit did you purchase?
Lift, lift parts, tires, wheels, axles, tcase, trans, brushguard, sbc motor, etc Paintballa0788 SEC For Sale / Wanted Forum 20 February 13th, 2011 11:57
Rough Country adjustable lift shackles. Up to 2" lift Illeagle SoCal For Sale 3 December 10th, 2010 08:31
2 Skyjacker front shocks 6" lift, 2 rear adj Rancho 9000XL 4.5 lift element96x NAC Classifieds 2 June 12th, 2010 14:02
is a lift kit worth buying over buildng a cheap junkyard lift? blazinjames Modified Tech Discussion 8 May 5th, 2010 07:20
Entire EXTRA 89 XJ with 6.5 inch lift, im selling it all, parts and lift generalleexj For Sale: Private Party Only. XJ ITEMS ONLY 30 February 4th, 2007 14:08
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
