Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old March 9th, 2021, 12:31
bankstre93 bankstre93 is offline
ZJ transmission rebuild
Tranny went out in my 97 GC ZJ this morning. Rebuild kit is on its way ($180) but Iíve got no clue what Iím doing. Itíll be one hell of a hands-on lesson I suppose.
Old March 15th, 2021, 20:49
Anak's Avatar
Anak Anak is offline
Stranger
Re: ZJ transmission rebuild
One thing I can warn you about: There is a seal deep inside which has to do with the 2-3 shift. The factory seal is slightly too small. The kit you will receive will come with both the factory size seal and the new, thicker seal. You probably want the thicker seal.
My '97 ZJ supposedly has a rebuilt transmission. However, it won't shift into third until I get up to 45 or 50mph. Once it gets well warmed up it behaves, but for the first 20 minutes or so it is a pain. Theory is that when the transmission was rebuilt they matched the seal to the one they removed rather than installing the thicker seal. Replacing that seal is full teardown.
Old May 23rd, 2021, 23:12
RickDT RickDT is offline
Howdy! How's the replacement of the new tranny?
Rate This Thread:
AW4 transmission rebuild or swap Alwaysdutch OEM Tech Discussion 13 September 28th, 2014 13:45
AX-15 Transmission Rebuild or Replace? lweiman Colorado Chapter 0 September 10th, 2012 08:41
Transmission rebuild cost???? 96country OEM Tech Discussion 14 September 3rd, 2011 03:57
Rebuild a Manual transmission? BSD Non-Tech / Off Topic 3 February 13th, 2006 06:55
Transmission Rebuild Cost 88XjLaredo OEM Tech Discussion 10 October 24th, 2005 19:58
