Old August 16th, 2007, 06:59
snxboardchk's Avatar
snxboardchk snxboardchk is offline
Exclamation help!!!! brake caliper
so yesterday i decided to change out one of my wheel studs, while going to put back on the brake caliper, the piston wont compress! broke 2 c-clamps.
how would i go about fixing this rather than getting a new caliper, (since i have no way to get anywhere). ????
Old August 16th, 2007, 07:17
JNickel101's Avatar
JNickel101 JNickel101 is offline
Re: help!!!! brake caliper
take the whole caliper off, disconnect the brake line, you should be able to pull the piston out of the boot...check the inside to see if theres anything out of the ordinary...
before you do that though....if you loosen your brake bleeder screw, do you get any fluid coming out?
Old August 16th, 2007, 07:30
im not able to go outside right now to pull anytihng out since its pouring raining, but last night we loosened the brake bleeder screw and yes fluid was coming out.
Old August 16th, 2007, 07:31
actually no, that was the brake line, not sure what the bleeder screw is? lol
Old August 16th, 2007, 07:34
bikertrash2001 bikertrash2001 is offline
Make sure you're pressing on the center of the piston or you will get it cocked in the bore. I know this sounds a little wierd since ther is a hole in the middle of the piston, but use a piece of wood or metal to cover the piston and keep the clamp centered. Oh and also take your master cylinder cap off to let the fluid move back into the MC.
Old August 16th, 2007, 08:04
JNickel101's Avatar
I think Bikertrash2001 hit it on the head there, forgot to ask if you took the cap off.....
Old August 16th, 2007, 08:37
jeepcomj's Avatar
jeepcomj jeepcomj is offline
he's got it cockeyed I bet...no biggy use the wood and clamp on center part.
little word of advice. when you're doing new rotors or even old rotors, compress it while removing it (just after you take out the bolts) and be sure to compress it farther than you need to. then re-install will go much better.
Old August 16th, 2007, 09:12
1985xjlaredo's Avatar
1985xjlaredo 1985xjlaredo is offline
You might have after market calipers and some of them screw into the caliper body instead of compress. Sounds like maybe it froze up on ya. Do your self a favor and just go get new calipers and pad and rotors. If you can do it yourself then it should be about 120 bucks for ok parts
Old August 16th, 2007, 10:29
its the push in kind because weve pushed it in before.
im just going to get a new brake caliper, even with all the brake fluid out of the caliper, it STILL isnt going anywhere.
Old August 16th, 2007, 11:42
jeepcomj's Avatar
good luck
Old August 16th, 2007, 12:00
meengreen's Avatar
meengreen meengreen is offline
I think bikertrash2001 might be right. I bought a special tool for compressing the piston back into the caliper. A C-clamp doesn't line up right and doesn't really push the piston in straight. The tool I got was less than $10 and works perfectly.
Old August 16th, 2007, 12:59
imfrankyj imfrankyj is offline
Get a new one! I had one lock up on me that was no fun at least we were close to home.
Old August 16th, 2007, 17:29
i wound up getting a new caliper, brake pads, and fluid, costing me $60 and taking 45 min. problemooo solved.
exploding brake caliper OCMI_Teddy OEM Tech Discussion 13 August 4th, 2007 10:37
brake caliper install BrianMU OEM Tech Discussion 5 June 17th, 2006 20:52
Brake Caliper bustednutz OEM Tech Discussion 1 November 16th, 2005 10:54
brake Caliper loose Gil BullyKatz OEM Tech Discussion 1 March 28th, 2004 17:30
What does the brake caliper thread into? xj92 OEM Tech Discussion 12 November 17th, 2003 13:32
