Old October 5th, 2021, 10:20
Fsjcherokee Fsjcherokee is offline
4.0/AW4 swap help
I tried searching forums but it did not like what I was searching or could locate a thread. Apologize if this is a sticky somewhere. Hello I was recommended coming by the jeepforum guys. I have a 1995 YJ that someone swapped in a 1995 XJ 4.0/AW4 the wiring was pretty chewed up by mice but it still ran and drove before I swapped out the dash/interior harness that I sourced from a 95 YJ.
I believe what they did originally was used the entire XJ harness and integrated a lot of it into the dash. I am trying to clean things up and make it right again. However, I am having one hell of a time trying to source the engine side bulkhead pinout with the labeled pinout diagram. I can find the YJ version galore and even paid out to all data and their diagram I believe is for the pinout on the interior side and it is also not labeled,,ie turn signal, vss feed, etc.
I need this to hopefully get this back up and running again. If anyone has done this and lives near the West Central Indiana area I am more than happy to pay you for your time. I do not know why this particular year/model is such a cluster to find the information. I have even purchased a Chlitons manual and that diagram is missing all together. Or if someone could please send me a clear and accurate engine bay said bulkhead pinout you would be a God in my country. Thank you for your help.
Old October 5th, 2021, 21:49
Unclewolverine Unclewolverine is offline
Re: 4.0/AW4 swap help
Sorry, I have a 95 but it's rhd and I can even find a correct fuse block diagram. You are almost definitely going to need to find someone who has taken the time to label it by hand because I bet it doesn't exist otherwise.
Old October 6th, 2021, 06:36
Anak's Avatar
Anak Anak is offline
Stranger
You might want to post in the Midwest chapter. That is a healthy group, and there might be someone within range who can help you out.
What you want should be in the FSM (Factory Service Manual). Chilton's is like the Cliff's Notes of the FSM. However, be aware the FSM is copyrighted material and is strict about not sharing images of that material on the site.
Old October 6th, 2021, 11:50
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
When I bought an FSM for my 92, what I got was one that covered the XJ, MJ, and YJ all in one set.
I did a quick look on factoryrepairmanuals.com (one place you can buy legal copies of the FSMs), and it looks like the 1995 manual covers both XJ and YJ (meaning you'd have both vehicles' info in a single manual set). Unfortunately, they show the 1995 manual as out of stock.
Interestingly, when I Googled for other legit sources, I found that Summit Racing lists the 1995 as available from them as well, and I noticed a couple listings for used copies on eBay as well.
For the magnitude of project you're facing here, buying the FSM would be money well spent. I'm not much of a wrench myself, but even I've found the FSM an invaluable resource.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
88 4.0L Renix to 96 4.0L HO swap...full swap? swommack2 OEM Tech Discussion 8 June 24th, 2017 08:38
86 Radiator Core support swap/ AC swap ,,, need info AV8R TRANSPORT Modified Tech Discussion 6 August 16th, 2015 23:19
Brakes- booster/MC crapped out, debating swap to synthetic fluid during swap heshhash OEM Tech Discussion 7 December 6th, 2014 09:57
Looking for two build threads...unibody swap and engine swap ffjosh Modified Tech Discussion 19 July 31st, 2012 21:26
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 13:40
