Old September 17th, 2021, 16:33
JoeBabs JoeBabs is offline
True Daytime Running lights
I've watched many YouTube videos and searched around on the forum and I am either overlooking the answer or am wrong about the YouTube videos.
First things first, '99 XJ, 2 door Sport, 4.0L, Manual, 4X4. Here are the lights I will be installing, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Every YouTube video I've seen taps into the turn signals or parking lights to power the daytime running lights. This would mean, I would need to pull the headlight switch out 1 notch and have my interior displays dim (I have a double din with CarPlay) to power the DRL. I saw Jeep Cables sells a headlight harness upgrade for $80 but it doesn't seem worth it if I can just steal 12V from somewhere else to power those little LEDs.
Ideally, I would just turn the key and the DRL would come on. Can someone help me find a power source for this that won't blow a fuse. I saw that Canadian XJ's had a DRL module, I am confident I don't have that.
Thanks
Old September 17th, 2021, 16:48
RCP Phx RCP Phx is offline
Re: True Daytime Running lights
I have similar lights on my 2000, I never had DRL's prior to installing them(17yrs), and now I have them with zero wiring changes.
Old September 17th, 2021, 17:20
There is a red wire on my lights specifically for the DRL. I need to power it somehow.
Old September 18th, 2021, 06:59
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Any 12 volts positive wire circuit that is IGNITION ON/OFF can be tapped into and will do the job. Grab your $6 -15 volts/ohms multi meter and probe around with the ignition ON and OFF.
The fusebox area has plenty of IGNITION ON circuits, installing a supply wire from the interior to the engine bay is not difficult.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old September 18th, 2021, 07:26
Both sets of mine only have the standard h4 connector.
Old September 18th, 2021, 07:41
Anak's Avatar
Anak Anak is offline
Stranger
So how are they getting "ignition on" power?
Old September 18th, 2021, 09:05
Couldn't tell you....... https://www.naxja.org/forum/showthread.php?t=1130887
Old September 18th, 2021, 09:25
maxbraketorque maxbraketorque is offline
My LED head lights are doing the same thing. They appear to be designed to do this in the regard that its only the set of decorative lights around the perimeter that are turned on when the light switch is in the off-position. Interestingly, when I turn on a turn-signal, the decorative lights in the head light on that side of the vehicle blinks with the turn signal.
I think the self-evident answer here is that the factory light harness runs at a low voltage when the light switch is in the off-position and the ignition is in the "on" position. I've been tempted to pop out a head light to measure, but too lazy right now.
Old September 18th, 2021, 10:23
I liken it more to how a led fuse lights when it's blown.
Old September 18th, 2021, 14:02
What lights did you install?
Old September 19th, 2021, 04:40
Thanks for the input fellas but it has not helped me find the 12V source the lights I am installing require.
Anyone have any ideas? Thanks you!
Old September 19th, 2021, 07:34
Tim_MN's Avatar
Does your Mother tie your shoes every morning ?
Old September 19th, 2021, 14:34
Thank you for adding so much value to this already worthless thread. Im glad I posted here to see if anyone else has done what Im looking to do.
Since no one seems to have already poked and prodded and found a good source, I will go ahead and do it once I finish up installing my new upper control arms, bushing, shocks and springs.
Again, the help on this forum so far has been truly top notch. Tim, thank you for your insight and time it took you to reply. I know it took longer to put ON and OFF in caps which ensures I am clear about the position of ignition.
Old October 3rd, 2021, 21:26
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
I too have a set of Angel Eyes LEDs that I plan to
connect the DRL portion later.
I'll use a piggyback fused connector plugged into
a switched slot.
My question: should I use a relay in the DRL circuit,
even though the LEDs current draw is so small?
LED Rock Lights , Interior Lights , Daytime Running Lights , etc. freerider15 Colorado For Sale/Wanted Forum 2 December 2nd, 2019 22:15
Daytime Running Lights CAD 90renixxj OEM Tech Discussion 3 August 23rd, 2017 22:46
DRL's on your US XJ (Daytime Running Lights) Secshunate Modified Tech Discussion 7 October 25th, 2007 19:18
daytime running lights module PolishX Wanted: Private Party Only 0 November 14th, 2006 08:45
Daytime running lights?? sys_eng OEM Tech Discussion 21 January 18th, 2006 05:45
