Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old September 17th, 2020, 04:17
bradleyheathhays bradleyheathhays is offline
Heater duct door switching problem
Have an '02 Taurus w/ 103k miles and about 6 months ago all the air, heat or a/c, started blowing only out of the defrost vents at the bottom of the windshield. All the settings work correctly except air has stopped blowing from the floor and dash vents entirely. I know the fix on this is probably easy, just getting to it is gonna be hard. I've had the dash off my '11 Crown Vic to replace the leaking heater core so I've got a little experience doing this sort of thing.
Can any describe to me what switching door in the vent system has gone bad and how I might approach fixing it?
Thanks
Rate This Thread:
Weird lighting problem after switching to LEDs hot_rod_hooligans Modified Tech Discussion 18 December 22nd, 2015 14:40
switching door locks kidarkitect OEM Tech Discussion 9 November 15th, 2009 18:14
Switching Front Seats 4 Door tgregg OEM Tech Discussion 2 January 1st, 2009 15:28
Heater Fan Problem cmeuzelaar OEM Tech Discussion 11 January 23rd, 2005 13:10
Heater problem Zoro OEM Tech Discussion 5 December 23rd, 2004 21:24
