Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old May 27th, 2020, 18:49
pezman65 pezman65 is offline
Long arms?
1st of all I have a 91 Cherokee with RE 4.5 lift running 33s. I'm looking to do a long arm upgrade what would you guys suggest? I look at rusty's and they seem like they're the cheapest ones but are they any good I think they're about 700 bucks .Clayton's pretty expensive . please chime in and help me out thank you! Also how hard to put in? Thanks much
Sent from my SM-N950U using Tapatalk
Old June 18th, 2020, 10:49
smokeyyank smokeyyank is offline
Re: Long arms?
cRustys suck. Either Stinkyfdab, Ironman or IRO. If you're on a budget IRO makes good stuff for the price. Ironman will be the most but their stuff is STOUT af. Stinkyfab great all around.
Old June 22nd, 2020, 12:32
Long arms?
What are IRO?
Old June 26th, 2020, 10:58
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: Long arms?
IRO= Iron Rock Offroad
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old February 18th, 2021, 05:59
75SV1 75SV1 is offline
Re: Long arms?
https://www.ironrockoffroad.com/cate...lift-kits.html
Rate This Thread:
Long arm fitment questions using RE Long arms Nugget Modified Tech Discussion 4 April 5th, 2015 21:07
Long arms vs mid arms rkates Modified Tech Discussion 11 December 6th, 2012 17:08
ford 44 radius arms to long arms need ideas BigRedMachine Modified Tech Discussion 2 January 23rd, 2008 19:45
Short arms, vs. long arms, vs. RE drop drackets Toyman Modified Tech Discussion 20 February 15th, 2006 02:49
Long arms and upper control arms. Dann Modified Tech Discussion 22 September 7th, 2003 13:17
