Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Commander XK (2006 - 2010)
Jeep Commander XK (2006 - 2010) Technical forum for the full-size Jeep Commander.
Old May 20th, 2018, 10:11
WB9YZU WB9YZU is offline
Service 4WD System
I pulled the boat to/from the lake yesterday, and put the T-Case in 4-LOW to back the boat up a grassy area where I store it. When I got done, the T-Case would not come out of 4-LOW, and the Service 4WD System message was lit.
After a few re-starts, I got it into 4-HI and put it in the garage.
After a restart the T-Case is stuck in Neutral. Sometimes I can get it engaged enough to get it to move forward (Which doesn't help because it was driven into the garage).
If I turn the key on, but don't start, I hear the fuel pump, then a few seconds later the transfer case motor. Sometimes it grinds for a tiny bit, sometimes it carries on for some time.
Sounds like a bad selector motor to me.
Has anyone had experience with this? Can I get underneath and manually select 4-Hi just to get the thing going?
Old May 22nd, 2018, 12:12
Re: Service 4WD System
I've been putzing with it and looking at the FSM. Don't have a code reader for the FDCM, but I am getting voltages at the shift motor connector.
The setup is interesting enough. The shift motor contains a motor, electric clutch, 3 sets of planetary gears, and what I can only surmise is a potentiometer. The Electric clutch must disengage for the motor to move, and the POT keeps track of the shaft position.
If the Clutch does not release, the motor can not turn.
Took the shift motor apart and found that a bit of case lube had made it's way into the motor and made it past the gaskets. I cleaned it all off, cleaned up the commutator and reinstalled it. Still no go and figured the sensor at the base of the unit had gone kaput.
I found a place in town with a new motor, so I replaced it $370 - no go
So now that I look at it, I think the issue is the Clutch is not disengaging, and is killing the motor.
That's probably why I've been reading about people who have had the recall done having to replace the shift motor afterwards.
Anywho, Along the way, I found I can manually select the transfer case by moving the shaft the motor engages with. As this is reachable without lifting the vehicle, it seems like a reasonable emergency ""Fix"". I'll need that to get it to the dealership...
This is starting to sound expensive - Volvo AWD Service expensive
Old May 22nd, 2018, 12:34
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
if you can move the shaft by hand and select the case, perhaps a linkage could be improvised to replace the motor with a manual shifter?
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old May 23rd, 2018, 07:30
There is actually a write up on one of the forums where a guy was working on manual control of the motor which would bypass the FDCM completely.
I took it to the Dealership this morning.
They have a Scan Tool which will read the FDCM's codes and I'm really interested to see what they come up. According to Chysler's records, my vehicle has had both the recall solutions for the T-CASE shifting issues done.
Old May 25th, 2018, 10:25
Here's the Tech's diagnosis.
Reset Service 4WD code using Scan Tool.
Reinstalled Customer's new Transfer Case Selector Motor.
Tested Transfer Case in all ranges and Road Tested.
Looks like I did 1/2 the diagnosis, and they did the rest.
I am real confident the original motor was not working correctly, but having to have a special tool to talk to the FDCM was keeping me from completing the repair.
I guess I need another tool to work on Jeeps now :O
Old May 25th, 2018, 11:32
NAXJA Member #920
Good to know. Might want to provide details on the scan tool for future reference if it's something special.
1984 Dodge Omni
Converting the 4.0L OBD2 fuel system to a return style system? Boostwerks.com Modified Tech Discussion 24 June 13th, 2015 08:43
Home security system DSC Alexor 2-Way Wireless Panel sensors complete home system RWKHausSupply SoCal For Sale 1 February 10th, 2014 09:56
What anti lock brake system is used on a 1992 Cherokee? Is it the same system used on bass4x4 OEM Tech Discussion 5 January 30th, 2014 00:21
How to convert closed system to open system? kcclark OEM Tech Discussion 3 July 26th, 2009 16:37
87 closed system to 92 open system radiator conversion the_bandit87 OEM Tech Discussion 3 June 23rd, 2008 12:20
