Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Comanche MJ (1985 - 1992)
Jeep Comanche MJ (1985 - 1992) Jeep's Cherokee-based compact pickup technical forum.
Old May 8th, 2016, 16:01
scguy27 scguy27 is offline
89 Comanche DD Build
Just picked up my first MJ, an 89. 4.0, AW4, RWD longbed.
She's a little rough, but runs and drives. For a little bit, anyways. Overheating, had a head gasket done and that didn't fix it, PO thinks it has a cracked block. For $350, I can't complain.
Plans:
4WD swap, HO engine swap. lift in the area of 4-6", just a clean DD.
Old May 8th, 2016, 16:11
Re: 89 Comanche DD Build
Carpet and seats pulled tonight. More rust than I thought.*
Being in SC I have very little experience with fixing rust, but this looks minor enough just to patch and not replace the entire floor pan right? What should be my course of action?
Poking with a screwdriver, this is all the holes I could find.
Seat bolster bent to crap...
Old May 8th, 2016, 16:13
Here is my organ donor. 92 XJ Sport, 4WD, NP231, AW4. D35/D30 3.55.
It has a new cylinder head with 5k miles on it, new fuel pump, distributor, starter, spark plugs, cap and rotor, Comp Cams custom grind cam, lifters, new header. It has the 01 intake manifold that has been port matched and coated with gold heat wrap with ZJ power steering pump (i think)
I also like the 3 row aluminum radiator and triple electric fan setup.
Not bad for $700.
Old May 11th, 2016, 17:36
831_xj's Avatar
831_xj 831_xj is offline
Looks like a clean find! I love those early bucket seats
I know a little bit about nothing..
Daily MJ
yewwy crawler
Old May 15th, 2016, 23:58
cheapcherokee93 cheapcherokee93 is offline
<----boat-manche
another spinnaker blue MJ! nice find
mine was originally from PA and literally had no floor on the driver side. Those rust holes shouldnt be too bad to fix
Old May 29th, 2016, 17:43
Donor's in the shop.
Couple hours of teardown.
Old May 29th, 2016, 17:44
Donor engine stripped of head and cam.
Cam and new timing chain installed
Oil pan gasket and paint prep on the 92 Jasper HO engine that will be used
Old May 30th, 2016, 21:05
Put in a few hours today.
Head on, new lifters in. New oil pan gasket and timing cover gasket, crank seal.
Primed.
And painted. I originally wanted to go with a different color, but black just fits everything.
This engine is a Jasper Reman with 26k miles out of a 92 Jeep Comanche. Current setup is 4.0 HO block bored .060 over, 7120 HO Head (mostly new, only 5k miles on it from Dover Heads in Atlanta), 01 intake manifold, Comp Cams custom grind (mild torque cam), and an aftermarket header of unknown origins,
Old June 1st, 2016, 23:04
hot_rod_hooligans's Avatar
hot_rod_hooligans hot_rod_hooligans is offline
I know that cam
Old June 2nd, 2016, 04:58
Originally Posted by hot_rod_hooligans View Post
I know that cam
How do you like it? Notice much difference over stock?
Old June 2nd, 2016, 21:08
Mines still sitting on my shelf, a sad side effect of being ADD, I bounce around from project to project a lot, some day I'll get back to that engine build.....
Old June 3rd, 2016, 06:21
I'm trying to decide on a lift. I want to run somewhere around 3-5". I'm torn between piecing a lift together or just getting the Zone 4.5"kit and a track bar. I plan on swapping the D35 out sometime down the road, so the add a leaf only needs to last till then when I go SOA.
Old June 4th, 2016, 23:49
Engine out.
Parts pile
"Patched" radiator
Interior stripped
Farewell, Renix
And none too soon.
And back outside. Not bad for a day's work.
Old June 11th, 2016, 06:59
Front axle robbed.
And transplanted.
Now if I can get these control arms bolted up.
Old June 11th, 2016, 12:41
Front's done. Got that squat like all the Chevys around here.
Ian's stupid comanche build eflores Other Rides and Builds 53 July 24th, 2017 23:14
My first Comanche.. -Build thread- NW-ZJ-SCOTT NorthWest Chapter 27 March 23rd, 2016 14:54
89 Comanche build thread XJ-ARNIE Midwest Chapter 167 March 8th, 2015 22:34
Comanche Build #2 BIGSLVRXJ Jeep Picture Showcase 39 September 7th, 2009 04:39
My 97 Comanche build shelbyluvv Modified Tech Discussion 70 June 24th, 2009 20:41
