Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Comanche MJ (1985 - 1992)
Jeep Comanche MJ (1985 - 1992) Jeep's Cherokee-based compact pickup technical forum.
Old April 29th, 2015, 08:00
043500 043500 is offline
MJ Crew cab.
I picked this up back in December. I'm sure at least some of you have seen the build thread on various sites out there...for $750 I could not pass it up.
It measures 18.5' bumper to bumper and has a 144" wheelbase.
My oldest son is 12 so we have some time to finish it before he can drive legally.
Here is a link to the original build thread and then the pic attached is of my son standing next to it in Lynchburg, TN the day we picked it up.
http://www.tnjeeps.com/topic/293-199...-cab-comanche/
If the link doesn't work do a google search for quad cab Comanche...it's on Tennessee Jeeps web forums.
It's good running driving jeep as is...the only things I need to do to make it what I consider 'road worthy' is have rear doors built, have 2x6 rockers welded in and then the body work to completely finish the roof line. The PO has 1 rear door to use as a mock up so making a good door will not be hard. I will also have the 2x6 rockers tied to the angle iron that is part of the new 'uniframe' which will make it even stronger than it is now...and I think it may very well be stronger NOW than the original XJ unibody...believe it or not!
As it sits now it has a 5-6" lift and is a 4.0L AW4 2WD. We crank it up and drive it around the neighborhood all the time. Believe it or not the guy did a GREAT job on splicing these to rigs together. It is solid and very quiet when going down the road...my '87 Comanche that's highly modified BUT never been really been cut on isn't as quiet as this!
The overall plan as of now is to sell my '73 scout II (just got it but it turned out to be a rusty pile because apparently I'm BLIND). Once that's done I should hopefully have enough to get the rockers welded in , doors done, and roof done.
I have a good set of rear XJ doors from a 4 door and as seen in KPTHEMP's Project Frostbite thread I bought his original doors from that MJ. The rear opening is about 8" shorter than the length of an MJ door. The plan is to cut the MJ door just in front of the main window...essentially removing the wing window and about a foot of door section underneath it...this way the back section of new door lines up correctly with the back of the MJ cab and MJ door striker. Then use whatever length of door is needed from the XJ rear door so the body lines and hinges line up correctly for the front portion of the new door. Then the only glass I will have to get custom made for it is a small rectangular piece that will go in front of the main window...AND the MJ window will still roll up and down as it did stock.
Long term is to convert it to 4WD and regear to 4.88...luckily it has the stock MJ D-44 in the rear, put on a good winch bumper and winch and then paint it. Will be putting it on 33's or 35's. It won't really be a trail rig just due to it's length and the fact I don't want to take the chance of it folding up...BUT I really don't think that would happen...it's done right.
I can tell you there will probably be long periods of time between actual updates due to LOTS of family stuff going on now and of course money seems to never be in abundance.
I cannot wait to start driving it though!
1993 XJ 2 dr, 5" lift and 32's
2013 JK sport 2 door
2020 JL sport 4 door.
Old April 29th, 2015, 13:25
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
Re: MJ Crew cab.
Nice rig! Ive seen that build thread at one point. very cool.
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old April 29th, 2015, 20:54
Just Differentials's Avatar
Just Differentials Just Differentials is offline
Differentials and Axles!
Re: MJ Crew cab.
That's a unique rig! I would love to see it on the trails with 60s and a set of 37 or larger tires. No matter what you do, it'll be awesome. Let us know if you need a quote for the gears when you are ready.
Old April 30th, 2015, 08:38
Re: MJ Crew cab.
Yeah I wish!
I will for sure look you up when I need gears.
Old April 30th, 2015, 12:40
collkid's Avatar
collkid collkid is offline
Re: MJ Crew cab.
Keep it stock. Convert to 97+.
That would be epic.
Old April 30th, 2015, 14:22
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Re: MJ Crew cab.
You realize that those are two conflicting ideas, right?
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old April 30th, 2015, 16:49
Kittrell's Avatar
Kittrell Kittrell is offline
Re: MJ Crew cab.
That would be epic.
Bad idea in my opinion. Since the rear door is 100% custom fab you will never get a door panel to match without spending a lot of money or having it look like crap. Since the older panels are just vinyl covered fiberboard you can get a 100% matching door panel made for not a lot of cash.
Old May 1st, 2015, 09:51
Re: MJ Crew cab.
Yeah stock is not much of an option at this point.
I've seen pics of a couple stock height of these and they're way too long to not be lifted with at least 33's.
I'd like to convert it to late model but it's way past that now.
Old July 2nd, 2015, 12:44
robert2008's Avatar
robert2008 robert2008 is offline
Re: MJ Crew cab.
Update on this? Would love to see if there's been any progress.
Old July 15th, 2015, 13:54
Re: MJ Crew cab.
No real progress yet.
I've sold one of our scouts and the money will go towards this once I have it all in hand.
I have recently purchased a good set of rear 4dr XJ doors and a set of good MJ doors.
I hope to be getting estimates over the next couple months to have the 2x6 rockers welded in, roof line completed and the 'new' rear doors fabbed up.
Once those things are done (hopefully by this time next year) then it's onto paint, 4wd conversion and gears in the axles/bigger tires..
I have procured a 4wd AW4...so at least that is out of the way.
We crank her up and drive her around the neighborhood a few times a month.
Old August 29th, 2015, 23:32
ComancheGuy ComancheGuy is offline
Re: MJ Crew cab.
Nice!!!
Old October 26th, 2017, 20:19
muddypunk muddypunk is offline
TOOL
MJ Crew cab.
Still alive? I know this is old as eff but hey what a gem!
Sent from my XT1609 using Tapatalk
Old December 1st, 2019, 15:03
Doanbuilt Doanbuilt is offline
Re: MJ Crew cab.
Hi I actually just picked up this crewmanche this weekend and I do plan to finish it, would be willing to find the original creator
Old December 1st, 2019, 17:33
Re: MJ Crew cab.
We got it in Lynchburg Tennessee.
If you Google crew cab Comanche, or 4 door Comanche, or 4 door MJ you should be able to find the guys original posts on other forums. I cannot remember his screen name but I want to say his real name is Dave.
Old December 1st, 2019, 20:25
smokeyyank smokeyyank is offline
Re: MJ Crew cab.
Check on comanche club. Theyll know
Parker 425 pit crew. tbburg Non-Tech / Off Topic 0 January 14th, 2009 19:11
My new Toy!! v. Gun Crew Tenny Non-Tech / Off Topic 34 August 5th, 2008 09:07
New to the Crew abzrocka Arizona Chapter 7 February 20th, 2007 16:26
New to the crew 88flexj Sierra Chapter 13 February 16th, 2005 13:55
