Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter
Colorado Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 35 votes, 4.89 average. Display Modes
  #5281
Old July 5th, 2019, 12:37
time2getdirty's Avatar
time2getdirty time2getdirty is offline
my cats breath smells
Re: What are you doing to your rig - the continuing saga
One ton, if you don’t have any gauges you don’t have to worry about lights.
Originally Posted by YELLAHEEP View Post
Probably gunna buy a JK.......
Old July 5th, 2019, 12:38
One ton, if you donít have any gauges you donít have to worry about lights.
Old July 5th, 2019, 13:03
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Lol, hopefully......
Mopar still makes 4.0 cranks?
Old July 5th, 2019, 14:26
1-tonxj 1-tonxj is offline
56027866ac Mopar $90 shipped . The master pro was $20 . This issue popped up when I was getting ready to head out for work so not much time to look into it , but My wire harness is very easy to trace since it's all visible running from the engine bay left side and right side back to the tail . I had an issue 6 -7 years ago the jeep would stall going from reverse into drive turned out when I installed the transmission I forgot to final torque the block to bellhousing bolts and I had about a 3/32nd gap between which was my issue causing it to stall shifting between reverse and drive ... My current issue could be something as simple a a ground or as much a pita as a flex plate causing the misfire .
Old July 5th, 2019, 14:32
Kittrell's Avatar
Kittrell Kittrell is offline
Originally Posted by time2getdirty View Post
All I know is it was a pre facelift and he always said it was the highest most fully loaded you could get ��*♂️ The hood and fenders currently on it are from a red 95 so maybe it’s a cross breed?
Nerd.
Not much original left so I couldn't say for sure. Top '95-'96 would be a Country with the leather option. All of the stuff that would visibly tell you that are long gone.
Old July 5th, 2019, 14:44
That's true ... according to my gauge cluster my air bag is not working properly, which is funny because it's working just fine tossed in the pile of parts sitting on the trailer next to the stock steering wheel that I cut the center hub spline out of to weld to my new wheel .
Old July 6th, 2019, 13:36
You pull the engine and slap in the crank or fight it in underneath?
Please keep us posted if you did your code, I still haven't fixed mine for a year.
Old July 6th, 2019, 13:38
Btw what are you looking for on the flexplate?
Old July 6th, 2019, 13:42
I think you missed the sensor part of him saying crank shaft sensor.
Old July 6th, 2019, 19:01
Sensor for crank position...aka... crank angle sensor...ckp...cps...not Z- crank shaft itself . If I do find a mechanical issue I'm just going to drop in a Golan 4.6 as I'm not pulling any drivetrain stuff to put stock back in . The 4.6 Golan has same power as a 5.3 v8 I would even add hesco heads to bump the hp up to about 300hp from 270 . A 6.2 gm and 6l80 would be great and probably not much more than a 4.6 Golan and hesxo head , but a stroker bolts in over a weekend with nothing needed but fine tuning and on the trail b.s another long project and having to settle for watching people wheel on boob-tube
Old July 6th, 2019, 23:45
Just re read, I missed it by a mile.
Old July 8th, 2019, 10:37
freerider15 freerider15 is offline
Some pictures of the xj buggy. 4.0, rad shifted aw4, 231, jk d30/44 with 5.13s rcv shafts front and rear, tnt suspension all around, body ditched, 38Ē stickyís.
Cool to see you've got a rig to wheel, really sorry to hear about your buddy. Not the way you want to inherit a rig.
Old July 8th, 2019, 10:42
Let's see...I jump back and forth between my two rigs
Buggy:
Front end (e.g. axle) finally assembled out to the hubs. I'll get the ORIs charged and tires bolted on and roll it out of the shop for a wash.
From there other than making the new driver's side floor board, should be a pretty quick assembly.
Blue XJ:
- Recharged the A/C system. Turns out one of the lines on my accumulator where it goes into the evaporator blew off. After some looking, I realized the way I bolted the accumulator in, it was trying to pull out (needed to rotate it more towards the firewall, push in the fittings, THEN bolt it down). So far so good, though haven't run it much.
On the other end of things, my electric fan wasn't kicking on at all (brand new fan). Sam and I walked through everything, and I determined the PCM wasn't grounding out the relay for some reason. Yesterday, I decided to swap in a spare PCM I had...and viola...working e-fan.
Now to try and get the front and rear bumpers knocked out before COFest....
Old July 10th, 2019, 01:18
Gunter's Avatar
Gunter Gunter is offline
Post Re: What are you doing to your rig - the continuing saga
has anyone tried Nick Risely's 4 wire O2 sensor mod?
Old July 10th, 2019, 14:01
Kittrell's Avatar
Never heard of it.
Rate This Thread:
Death wobble, the continuing saga RockTracXJ Modified Tech Discussion 11 June 2nd, 2010 06:46
Continuing the downward spiral of 4x4 design Lawn Cher' Non-Tech / Off Topic 28 April 19th, 2010 12:49
The saga continues... sams88 User Support, Questions and Suggestions 0 September 1st, 2007 23:08
1990 AC saga keeps going... cherokee4fun OEM Tech Discussion 14 June 13th, 2007 22:02
'00 Headers, and the continuing lack of them KCNMDE Modified Tech Discussion 0 August 8th, 2004 15:21
