Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > The Daily Driver
The Daily Driver A technical forum for the ride that gets you to work every day.
Old October 5th, 2020, 08:41
blenny blenny is offline
RRC President
Another CPS question 91
91 Comanche sat parked for 5 years. Did some work (cap/rotor, plugs, wires, coil, ect). got it running ok, but still had a miss. Changed the CPS with a parts store unit (dunno which). Ran great after about 15 seconds warming up. Now it will completely lose spark after driving around 20 minutes. Crank no start. After sitting it will start again. Maybe heat issue with CPS I have read about. Now the question.
TLDR
For 91-93? the 4.0 used a 3 prong round rubber plug CPS, it seems it is no longer available from Mopar, any ideas where I might find a good one?
Rate This Thread:
Wheel Hub question/limp, poor handling question - been researching fishinpolejoe OEM Tech Discussion 3 December 5th, 2016 20:03
Brake Upgrade Question (with Transfer Case Drop BONUS Question) NateEnos Modified Tech Discussion 9 April 13th, 2011 15:41
Question for those with Durango steering box: Pump question jdbwrx Modified Tech Discussion 7 November 23rd, 2009 15:39
Super quick question before I head out the door to the Junkyard. 99+ intake Question. Plays For Jeeps Jeep Street and Performance 26 October 13th, 2008 07:25
98xj 4.0L high idle question code question rapom OEM Tech Discussion 4 June 27th, 2005 17:18
