AC Clutch Cycling But AC not on?
alloriginaltone
Pittsburgh
So this is weird...my A/C clutch is cycling but the A/C is not turned on. The system dial was set to defrost/lower foot mix (the heat side ...not AC side) and the temperature mixer was set to warm.
Any ideas on diagnostic procedures?
It's a 2001 Sport.
That is normal, the a/c engages in the defrost mode to pull moisture out of the air.
You have no issue.......carry on.
