jd350az
- Mt. Lemmon, AZ
Everything I can find online says #13 in the fuse panel under the dash is a power door lock fuse. Mine keeps blowing, but I don't have power door locks, or Windows. And now the jeep won't start. The fuel pump isn't coming in at all. I went searching for a fuel pump fuse but nothing is coming up. Then I found #13 blown, replaced it and it blew again. I'm pretty sure I'm going to find lots of electrical problems with this XJ, previous owners seem to have done some weird things. Where should I start to diagnose the fuel pump issue? Would cps cause that or would it at least run the 3 seconds when you turn the key on?
