Old March 11th, 2008, 13:50
Grumpy's Avatar
Grumpy Grumpy is offline
$1500 - $2000 Build.
So I ran into a 96XJ for free, it needs a tranny but I have one lined up and a friend is putting it in for me.
Since I got this one for free I still have $1500 that I put a side to buy one. With that money I want to build up the XJ. I don't want to go anything bigger than 3.5" lift for now. Can you all give me some suggestion on what I should do witht he money. This will be my 4 XJ but the first time building one and I don't know where to start.
I have tow straps and all the necessary equipment so basicly I just need to build the thing.
Old March 11th, 2008, 14:00
Ba-Riedo's Avatar
Ba-Riedo Ba-Riedo is offline
has frame envy
Re: $1500 - $2000 Build.
Rockrails, a good tranny/ tcase skid, cb, lights, tow points front and rear. You said you wanted a 3.5 inch lift so probably some 31's, and a rear locker. Do you know what axle is in the back? If it is a 27 spline 8.25 you can find some cheap locker options, but if its a dana 35 I would suggest upgrading.
-Alex
Old March 11th, 2008, 14:59
Grumpy's Avatar
Yeah it is the Chrysler 8.25. Glad I got that one.
Old March 11th, 2008, 16:25
96XJ Country's Avatar
96XJ Country 96XJ Country is offline
Check the build date or something to see If you have the 27 or 29 spline... the later 96's were blessed with 29's even though its said they are only post 96
Old March 11th, 2008, 16:40
Darky's Avatar
Darky Darky is offline
Get a lunchbox locker for the rear, some S10/Dakota/BroncoII leafs to build a bastard pack for the rear. Search around, you can find coils for cheap. I have some 3.5" REs selling for $125, so they're out there. Longer lower control arms, YJ brake lines, t-case drop can be either bought fairly cheap or made even cheaper. If you want bigger than 31" tires, you can cut the fenders out to run 32s, or even 33s if you cut a lot and bumpstop properly. And you'll want gears too. That should all come in around that price range maybe even a little left. You'll want some sort of protection for the underbody at that height.
Old March 11th, 2008, 20:25
Parker454 Parker454 is offline
use 91 till they stoped making v-6 0r v-8 coils springs off a t-bird or couger .and spring pack off s-10. ford f-150 shocks in rear t-j shocks up front,works great,did my whole lift for about 125$
Old March 11th, 2008, 20:56
xcm xcm is offline
do it right
re 3.5 w/ leafs
+ craigslist tires
forget rock rails, who cares it was free
2000 Dodge Ram 1500 Jeepguy91 MWC For Sale/Wanted Forum 3 August 28th, 2008 15:22
'88 XJ 4.0 AW4 DD $1500 OBO Gil BullyKatz MWC For Sale/Wanted Forum 7 December 6th, 2007 20:43
will not rev over ~1500 rpm 97Halfback OEM Tech Discussion 10 May 20th, 2007 18:46
97' xj in NC for $1500 XJrambler SEC For Sale / Wanted Forum 4 January 8th, 2007 17:41
