Old February 6th, 2006, 13:51
FRAM's Avatar
FRAM FRAM is offline
Fuel Pump Relay/Fuel Pump wire in the cab?
I have a 90 XJ Limited and I would like to add an disconnect to the fuel pump. I have an 88 FSM and the wiring diagrams do not quite match my 90 XJ.
I was wondering which wire do I need to interrupt for the fuel pump or fuel pump relay. I prefer to do the connection in the kick panel or near the fuse panel if possible...
Old February 6th, 2006, 14:00
langer1's Avatar
langer1 langer1 is offline
Re: Fuel Pump Relay/Fuel Pump wire in the cab?
At that point I think it's pink and black, under the hood it's orange and Black.
Old February 6th, 2006, 14:05
Menzenski's Avatar
Menzenski Menzenski is offline
Formerly Mambeu
You mean like this?
Old February 6th, 2006, 14:11
FRAM's Avatar
langer1: Thanks for the info. I will check it out when I get home.
Mambeu: Yes like that but with a relay and an alarm system versus the switch. Thanks for the link. I think the wiring is slightly different on a 94 XJ
No Fuel Pressure, 6.5 Volts at pump connector Inthemudbud OEM Tech Discussion 10 November 23rd, 2005 09:52
Fuel pump questions. PFunk242 OEM Tech Discussion 4 August 26th, 2005 06:32
fuel pump replaced aarong OEM Tech Discussion 3 August 13th, 2005 18:04
3rd Fuel Pump in 12 months DrCabe OEM Tech Discussion 4 April 5th, 2005 19:30
Fuel Pump or WHAT ?? geepers OEM Tech Discussion 4 February 17th, 2004 07:53
