Old March 1st, 2023, 08:46
Walker4x4 Walker4x4 is offline
Error codes: p0123 and p0122
Okay so here’s my issue. The jeeps been acting up for a while. Idles at 1500 rpm, will not shift into overdrive, and when I floor it, it gets to about 2500 rpm and sputters. I’ve been looking deep into this and I saw someone who said the clock spring may be throwing the code. The blinkers work intermittently, but it’s been doing that for a while. I pulled to horn fuse just to make sure, and it didn’t change anything. Next I replaced the tps, nothing. I replaced the iac valve and that fixed the idling issue but not the power surges and no overdrive issue. I pulled out the multimeter and tested the pins that go to the tps next. Here are the results:
I understand that pin 2 is getting voltage when it shouldn’t be, and pin 1 is getting a little too much, but I’ve never dealt with electrical issues and I have no idea where to go from here. Anyone ever experienced this? Any information is welcome and appreciated.
Old March 1st, 2023, 15:57
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Error codes: p0123 and p0122
I would suspect the clock spring.
Clockspring and TPS
A Jeeper had OBD-II Check Engine Light trouble codes P0123, and 0122, Installing a new genuine Jeep TPS sensor did not solve the codes or cure the symptoms. On the highway the driver noticed the cruise control didn’t work either, and the Jeep was sputtering/stalling, The turn signal was acting weird, sometimes it would turn on, sometimes not...sometimes it would blink 10 times a second like it had a bulb gone out. Others Cherokee owners report the odometer randomly goes blank. The cure to all the symptoms was a new clock spring.
COMPLAINT: TPS TROUBLE CODE WILL NOT CLEAR
A late model Jeep with a 2.5 or 4.0 liter engine and the AW4 transmission comes in with the “MIL” Check Engine Light illuminated and a complaint of late shifts. A scan reveals a code P0123, “TPS Voltage High”, is stored. The scan tools data list indicates that the TPS signal wire voltage is at 5.0 volts at closed throttle, and then ranges up to 11.5 volts. A back probe of the TPS signal wire (usually is an Orange/Dk Blue wire), shows 5.7 volts at closed throttle, with a similar rise in voltage as the throttle is opened. A check of the TPS 5 volt supply and ground circuit prove that both of these circuits are good.
A check of the TPS signal wire with the TPS disconnected shows the same 5.7 volts. Inspection of the wiring between the TPS and the PCM and TCM shows no faults. A replacement TPS does not cure the problem, neither does replacement of the PCM or TCM.
TESTING: Unplugging a faulty Clock Spring should return the TPS voltage to its’ normal readings. Or, you can remove the Horn fuse in your fuse block - this will remove the 12 VDC supply to the clock spring. Once the short circuit is temporarily disconnected, you should be able to reset the trouble code, and confirm you diagnosis of a faulty clock spring.
CAUSE: The Switch Sense circuit in the Clock spring in the steering wheel hub has shorted to battery voltage from the horn button circuit. When the Switch Sense Circuit shorts to the 12 volt HORN circuit the TPS signal voltage is driven high and remains there as shown. This is because the 5 volt reference voltage used by the Cruise Control “Switch Sense” circuit and the TPS are shared inside the PCM.
CORRECTION: Replace the Clock spring assembly. Once the Clock spring has been replaced be sure to check the sensor 5 volt reference voltage at the PCM to insure that circuit has not been damaged by the short to power. Also check the TPS signal range to insure the TPS has not been damaged.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old March 8th, 2023, 09:10
Update , it was the tps. I was sold a bad one
Old March 8th, 2023, 16:42
Tim_MN's Avatar
Thanks for the follow up. Good TPS test info also.
Old March 8th, 2023, 20:08
lawsoncl lawsoncl is offline
Don't worry, they probably just put it back on the shelf for the next guy.
Old March 9th, 2023, 05:35
Unclewolverine Unclewolverine is offline
I've gone through two bad ones in a row before :/
98 4.0L P0122, P0123, P0700, Wont Idle? Chris2552 OEM Tech Discussion 2 May 1st, 2019 04:12
P0122 error 2000 4.0 Sport xjintx OEM Tech Discussion 8 February 17th, 2017 06:56
2000 XJ TPS problems - p0122 and p0123 sumofatguy OEM Tech Discussion 6 June 8th, 2010 21:29
error codes monkeysxj OEM Tech Discussion 10 December 3rd, 2005 21:36
60MM THROTTLE BODY PROBLEM...HELP!! P0123 Error joey99jb Modified Tech Discussion 1 August 23rd, 2004 12:35
