Old February 21st, 2023, 11:26
Bmfinney Bmfinney is offline
Harness for the fan blower switch
Just wanted to post that they still make the old harness for the blower speed switch. Found one. Santech ac components: part number MT1670
Incase someone has one that is burnt up like mine was.
Old February 22nd, 2023, 03:27
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Harness for the fan blower switch
For which years?
Old February 22nd, 2023, 05:22
The older style I believe. 97 and back.
Old February 22nd, 2023, 05:27
https://ibb.co/XJB11Tn
Blower fan harness/resistor issue Volatile OEM Tech Discussion 10 September 27th, 2017 13:43
Is it ok to run the blower motor on speeds 1 & 2 with a melted harness plug? DerMeister OEM Tech Discussion 9 February 18th, 2014 20:42
Blower switch location? onesic6 OEM Tech Discussion 8 February 4th, 2010 19:19
Doh! Prongs from new blower motor not compatible w/ wire harness... Steve-o94XJ OEM Tech Discussion 5 December 9th, 2009 19:58
99 Blower control wire in ignition harness npcherokees OEM Tech Discussion 6 November 27th, 2007 16:02
