Old January 22nd, 2023, 11:32
maxbraketorque maxbraketorque is offline
Install axle u-joints with or without lube on press fit surfaces?
I've been watching a bunch of videos on axle u-joint removal and installation. Old u-joints are out, and new are ready to be installed after I finish a bit of clean-up and painting.
Most people put some sort of lube on the press-fit surfaces, but I came across a thread where a person adamantly stated that no lube should be used because it will cause the joint to slip in the press-fit surface during use. Anyone know the correct answer?
Old January 22nd, 2023, 11:45
JonnyCat63 JonnyCat63 is offline
Re: Install axle u-joints with or without lube on press fit surfaces?
I use some sort of lube on almost everything. Grease, anti-seize, lock-tite, dielectric grease, silicone grease, you name it.
On any metal threads or metal to metal contact, cars, plumbing, whatever, I use some sort of lube. For me, it aids in wear, and make the replacement process much easier.
I can remember years ago snapping a bolt off on one of my Ford vans alternator bolt. A steel bolt into an aluminum bracket, from the factory, no anti seize. Who thought that was a good idea?
I say yes, lube on everything, properly cleaned, torqued and/or assembled, never had any issues.
To quote and old Frank's Red Hot Sauce slogan: "I put that shit on everything!"
Old January 22nd, 2023, 12:36
RCP Phx RCP Phx is offline
Where would it "slip" to???
Old January 22nd, 2023, 14:35
I suppose the inference was that it would stress the c-clips. But I can only guess.
Old January 22nd, 2023, 16:15
lawsoncl lawsoncl is offline
Personally, I clean up the bores with a little steel wool and apply a little oil or antiseize so go in easier and don't get stuck the next time. The only force on the caps is to push the outward, and the clips will hold them. In fact, when you're done, give the u-joint a few taps in either direction to make sure the caps are pushed up against the clips.
Old January 22nd, 2023, 16:39
Thanks everyone. I filed off burrs and cleaned up the bores with a wire brush attachment on my drill. It looks very nice now. I'm a big fan of anti-seize as well, so I'll use a bit of that on the bores when I install the u-joints. Hopefully everything will go together without a hitch.
Old January 22nd, 2023, 17:56
Unclewolverine Unclewolverine is offline
I've always put them in dry and never had an issue.
Old January 22nd, 2023, 19:10
Anak's Avatar
Anak Anak is offline
Stranger
I just clean up the driveshaft/yoke surfaces and install the caps with whatever lube/protective coating is on them already.
Old January 23rd, 2023, 10:56
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
More likely it's because the lube could cause the whole cap to rotate with the joint (and, coincidentally, wearing the holes in the yoke) rather than the friction between cap and yoke holding the cap stationary while the joint rotates in/with the needle bearings inside the cap.
That said, it doesn't sound like most folks have that much difficulty getting those apart - it's not like the joint and yoke are different metals (leading to the galvanic corrosion/dissimilar metals issue that Jonny ran into with that Ford alternator).
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old January 23rd, 2023, 11:57
Seems like the u-joint bearing would have to be seized for there to be enough torque to cause the cap to rotate in the yoke.
Old January 25th, 2023, 17:52
That said, it doesn't sound like most folks have that much difficulty getting those apart.
I've done my fair share where the caps are rusted up and a bugger to get out. Some people manage to bend the ears trying to press them out (with poor technique in my opinion). If you break one while offroading, you'll be glad the previous installer used anti-seize.
Old January 25th, 2023, 19:11
Anak's Avatar
Stranger
That is a good argument for the use of anti-seize.
I used a shop press, and a few of my u-joints took some effort to start moving. A BFH might start things moving more easily, but generally dislike the idea of that approach.
Anyhow, I'm going to use some anti-seize. I can't see how a cap can ever spin in a yoke, and I figure that a bit of anti-seize will help with straightening the ears with a hammer tap after pressing in the caps.
Old January 25th, 2023, 19:20
Expanding on my comment on poor pressing technique:
I use a slightly different method for pressing or hammering out joints. I have a piece of u-channel that I stick underneath to support the cross of the joint or the ears on other sides. Then I stick a big socket on top of the upper cap and press on that. The result is forcing the cross and the upper cap upwards into the socket. Flip over and repeat to get the other cap out
The risk of the "traditional" method is having the upper cap bind up and instead of both caps moving downward, the bottom one moves and the upper ear bends inward.
Old January 25th, 2023, 19:29
Scroll to about 46 minutes to see the flipped over version of what I do. He uses a tool on top that presses downward on the cross instead of the upper cap. https://www.youtube.com/watch?v=U6QKs9JajQ4&t=2780s
Pre Lube Kit Install mflueras Modified Tech Discussion 2 December 27th, 2010 06:55
To install new bearings in a 9 inch, one needs a press..... JEONLYEP Colorado Chapter 20 May 7th, 2008 20:30
Front Axle Lube Lowrange2 Modified Tech Discussion 3 March 27th, 2007 16:55
No-slip install questions for 8.25, general pumpkin sealing, gear lube, etc Rusty from Cleveland Modified Tech Discussion 17 January 8th, 2007 06:52
can you lube both u joints in front diff on 90 xj lapaul OEM Tech Discussion 3 July 21st, 2004 07:45
