Old September 10th, 2022, 12:00
lawsoncl lawsoncl is offline
Re: 95 XJ Overheated, Shop says Head Gasket, need advice/info
Overheating that fast makes me suspicious that you either don't have coolant in there, it's not holding pressure and boiling, or it's just not pumping coolant. Could be a crappy water pump that failed, coolant leak, and/or the gasket failed. Being 27 years old, you're probably well overdue for a new radiator.
I'd be tempted to call around and find a good independent mechanic willing to troubleshoot a bit more that "bad head gasket - replace engine".
Old September 10th, 2022, 12:07
Etherel15 Etherel15 is offline
The radiators only a couple years old (the engine was swapped when I bought it at 130k, with a 35k motor, its about 170k now) but maybe the radiators not that great. It had overheated badly in December, and the pump and lines were replaced, so perhaps they did a shotty job?
I plan on getting another diagnosis, just hoping to wrap my head around what could be wrong, so I could be better informed when talking to a different mechanic/shop. knowing what I'm getting into will help with the stress.
Old September 10th, 2022, 12:14
It wouldn't surprised me if they put in a cheap pump and the impeller disintegrated. It would be really helpful to do a few of the basic tests like compression and leakdown which could confirm a bad head gasket before digging into it. Even just starting it and watching for bubbles in the radiator could be conclusive.
Got any neighbors or friends who are car savvy that might help for the low, low price of a 6-pack?
Old September 10th, 2022, 12:22
I desperately wish I did, I'm the one "fixing" other peoples weed whackers & faulty outlets. always the helper never the helped.
I'll try researching those tests. can't get the car back till Monday. still trying to figure out towing without paying another arm and leg (once again, I usually was the one doing the towing oh well)
2000 XJ Overheated. cracked head or block? montesxj2000 OEM Tech Discussion 6 March 16th, 2017 21:28
Head/Head gasket Woes After new Head, Steamy Exhaust KentsOkay OEM Tech Discussion 8 September 17th, 2015 13:44
F/S in MA: 1997 4.0 w/109k, blown head gasket and likely cracked head JrTxJ NAC Classifieds 8 November 29th, 2014 17:29
Head Gasket Question/Advice mudjnky OEM Tech Discussion 10 January 17th, 2011 09:47
Head Gasket Advice Tractionless2g OEM Tech Discussion 25 June 12th, 2006 16:04
