Old August 29th, 2022, 19:57
klint96xj klint96xj is offline
Seeking help with injectors not pulsing.
Hi everyone, I have a 2000 XJ with 4.0 aw4 and 242 t-case. I am trying to track down a wiring issue with it. I have a brand new pcm, coil, and CPS sensor, so I have a hard time thinking it is due to one of those items. I have spark, but I am not getting fuel. The fuel pump is kicking on, and I have adequate fuel pressure at the rail, but the injectors are not pulsing at all. The probe shows that both wires are recieving ground on every injector regardless of the key being off or in the run position. The number 18 fuse in the engine compartment is blown, which I'm guessing is due to the fact that both wires are grounded.
Can anyone help give me some advice on where to start my next approach on diagnosing this issue? I'm not much of an electrical guy when it comes to vehicles. Thanks for any help you can give, Klinton
Old August 30th, 2022, 07:47
RCP Phx RCP Phx is offline
Re: Seeking help with injectors not pulsing.
2 things that I see, 1 - the injectors are grounded thru the PCM so you shouldn't get a reading when the engine is off. 2 - what is the actual fuel pressure (adequate means nothing)?
Old August 30th, 2022, 15:56
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
2000 Fuse 18 is the Ignition Coil Rail and Fuel Injectors. A blown fuse very likely means a short circuit. A visual inspection for melted or chafed wire insulation, damaged wires and corroded bent or pushed back wire plug pins would be a good starting point. Test wire continuity between the injector and the PCM.
Is the ASD relay functioning ?
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Bad CPS= injectors not pulsing? natep1 OEM Tech Discussion 2 February 3rd, 2006 10:32
Pulsing at 60 mph a_tittman OEM Tech Discussion 0 October 13th, 2005 13:48
Still no Start - Injectors not pulsing - Please Help! NHXJer OEM Tech Discussion 20 August 27th, 2004 05:53
seeking fuel injectors,4.0 motor mike harris Wanted: Private Party Only 3 July 7th, 2004 21:03
Pulsing Accelleration? Skorpyo OEM Tech Discussion 0 July 17th, 2003 04:10
