Old May 24th, 2022, 15:41
tetatdo tetatdo is offline
Re: CA SMOG, HIGH NOx
Originally Posted by Rob Mayercik View Post
OBD-1 Logging? Very interesting, would like to know more. Got a link?
nothing that's useful. Its a russian forum.
I did grab their utility and ran it and got it connected and datalogging. I got a nice graph for the o2 sensor switching. The problem is the entire program is in russian. You have to build a cable to do this, its not very expensive but it requires some work to make it happen.
I had a cable built to talk to the ECU with my laptop for a whole other project I was working on.
Im not a software engineer but I did find a way to disassemble their program and found all the strings. I'm trying to find a way to translate their program and recompile it.
https://www.drive2.com/l/503862474496279278/
Old August 9th, 2022, 17:49
DKibbe6800 DKibbe6800 is offline
Man... I traveled back in time almost 10 years and read all 15 pages of this thread and thought for sure there'd be a solution...
Don't get me wrong, there is so much good info here. I haven't looked too much into my XJ yet because I wanted to read as much as I could.
I'll report back if/when I pass.
Old August 9th, 2022, 21:39
godspeed my friend!
I'm no tuner but in my case it seems like if i could just fatten up the fuel curve when its under load, and get the mixture a little richer, i'd have no issues passing.
Old August 10th, 2022, 07:08
Saudade's Avatar
Saudade Saudade is offline
When you have something to report, PLEASE start a new thread rather than continue to bump this relic. In case you fail, make sure you post all of your smog results, the year of your XJ and other relevant factors.
1988 Laredo 4L 2wd Auto, AKA "Grey Ghost", 208K
Old September 6th, 2022, 20:36
any updates @dkibbe6800?
failed smog high NOx jeddins OEM Tech Discussion 20 March 31st, 2010 03:08
Failed CA Smog - High C0 HTeK OEM Tech Discussion 12 May 18th, 2007 12:47
CA smog failed, high CO GroversXJ OEM Tech Discussion 13 November 22nd, 2006 15:47
Smog test, high HC Paul S OEM Tech Discussion 20 November 8th, 2006 12:16
CA Smog-High NO Bronco OEM Tech Discussion 3 February 11th, 2006 13:43
